03-29-2013, 03:41 PM   #1
Suggestions for a body just for manual lenses
I am a Pentax/Asahi collector and I have an sizable collection of K-mount (K, M, A) lenses (and M42). For a while, I was shooting them on a Samsung GX-1L (*ist copy) which allowed for stop down metering via a single button (Av and M). It worked fine until it was dropped a few years ago. I then proceeded to a used K10D which I thought was a good upgrade given the brighter prism viewfinder. To my surprise, I had metering issues with the Pentax K mount lenses.. very inconsistent which seemed to be a well known issue after searching around online. Its been a few years now and I'm looking for advice on a used pentax DSLR body that
* Allows for accurate stop down metering (as with the GX-1L)
* Would be nice to support metering wide open on KA lenses.
* Bright viewfinder (prism instead of penta-mirror?)
* On used market.
I've thought about finding another Gx-1L or *ist as they are probably available for very little given their age but I figure i could ask here first. I've been "out of the loop" when it comes to Pentax camera bodies released since the K10D so I'm unsure which of the later bodies have certain advantages when it comes to shooting with K-mount lenses.
Keep in mind, this is ~not~ my main camera system (Leica, Canon, Oympus) so I'm not looking for an investment on the latest and greatest. On the other hand, don't really have a budget either. I'm just looking for a body to enjoy my lenses.
btw...
How's focusing on the mirrorless Kmount cameras?
03-29-2013, 03:54 PM   #2
Docrwm's Avatar
The K-01 has a very good setup and excellent sensor performance. The one restriction is that AF on it is a single flavor vs. the dSLRs with two types of AF. If it's not your main system and you want to use your old lenses its a real steal these days as its been discontinued (the styling was not well received and if you don't own K mount lenses there really is very little reason to buy one).
03-29-2013, 04:03 PM   #3
For the M42 lenses you can buy an adapter with a focus confirmation chip and use them on your Canon body. I still have a 10D that I use for this. I've tried a K mount adapter but with the aperture linkage sticking out of the back of the lens just looks too scary. It looks like it might hit the mirror. I had a full frame Canon body that I had to pay $350 to get fixed because a wide angle M42 hit the mirror. With APS-C you don't have to worry about this.
As for focusing a K-01, it's not bad with focus peaking, but it takes some getting used to. The K-01 does show the flaws in older lenses more than older bodies because of the high resolution of the sensor. That's why I've been using the 10D. 6 MP doesn't show the flaws . If you want to stay Pentax then I'd go with a K10D or older. Just my opinion.
03-29-2013, 04:05 PM   #4
QuoteOriginally posted by usayit Quote
* On used market.
btw...
Get a K-5, as its DOF preview button makes stop-down metering a bit easier than on the K-30 or K-01, which require use of the green button and an additional setting change. The great IQ from the K-5 is an added bonus.
03-29-2013, 05:36 PM   #5
VisualDarkness's Avatar
But instead the K-30 got focus peaking, so I guess it's a matter of taste. Both K-5 and K-30 will work wonderfully!
03-29-2013, 05:39 PM   #6
dms
If you still have the ist copy--will the screen fit the K10d. I used k20d with ist screen and had no problems with exposure. Also the k20d allows e.v., bias in M mode--a feature not om my Kx and not (I believe) on the k10d. It is a nice feature.
03-29-2013, 08:28 PM   #7
wiseman's Avatar
QuoteOriginally posted by dms Quote
dms is correct, the K10D does not allow e.v. bias in the M mode. I agree that you would be better served to select a "newer" camera with this feature for use with your non A lens.
03-29-2013, 09:22 PM   #8
wiseman's Avatar
Could you please explain this further. Are you saying that there is some other way to to do stop down metering on the K-5 other than using the Green button? My only experience is with a K10D.
03-29-2013, 09:39 PM   #9
QuoteOriginally posted by wiseman Quote
You can use the DOF preview button also. Same effect as the green button.
03-30-2013, 03:05 AM   #10
Try the Pentax K5, as already suggested here!
03-30-2013, 07:55 AM   #11
Great. Thanks for all the suggestions!
No longer have the GX-1L.... wish I knew about the focus screen earlier. I'm assuming the K20D had similar exposure issues as the K10D? What other camera bodies should I steer away from due to similar issues?
I'm probably going to want to stick with a viewfinder so it looks like I'm deciding between the K5 and K30 (focus peeking adv). After some thought and ebay searches, the K5 is hitting probably the max I want spend. I'm still considering (as someone suggested) another pre-K10D body... but really would like a brighter viewfinder
03-30-2013, 08:03 AM   #12
dms
I don't believe the K30 allows M mode and e.v. bias--and for that reason alone I would suggest it is not a good vehicle for older K and M lenses.
03-30-2013, 08:14 AM   #13
DMS, thanks for your responses...
Can you explain why you think E.V. bias is so important in M mode for manual lenses? Perhaps I am missing something. I am assuming that it still has a under/over exposure reading in the viewfinder that ev can be simply adjusted by stopping up and down followed by another stop down reading.
03-30-2013, 08:16 AM   #14
audiobomber's Avatar
I find focus peaking amazing for manual focus, so the K-30 would be my choice in this price range.
03-30-2013, 08:16 AM   #15
NitroDC's Avatar
Either a K-30 or K-01. Focus peaking.
*ist, bodies, body, camera, dslr, gx-1l, k-mount, k10d, lenses, pentax, photography, viewfinder
A german Pentax Q user with a weakness for manual lenses GoldMark Welcomes and Introductions 4 01-10-2013 09:50 AM
Best Pentax body for manual focus lenses eagle_fly Pentax DSLR Discussion 13 11-16-2011 10:37 PM
Suggestions for an AF body. wacrider Pentax Film SLR Discussion 6 07-10-2011 11:00 AM
looking for a second body - suggestions? nobbsie Pentax DSLR Discussion 13 09-28-2009 06:52 AM
Just got an *istDS, looking for manual focus lenses capinbuck Pentax SLR Lens Discussion 8 02-15-2007 06:11 PM
All times are GMT -7. The time now is 02:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
