Originally posted by scratchpaddy I won't dispute your panning claim (awesome pic, btw), since I haven't really tested it, but have you actually tested long exposures on a tripod with SR on? I have, and 2-second exposure pictures randomly turn out blurry even when the tripod is on concrete and no one is even close to the camera. That was with a 14mm lens, so it was definitely caused by sensor movement. I have never had this problem with SR disabled.
With the K-r the slowest I have tried was a quarter second and they were OK. With the K-30 one second is about the slowest it will go without causing any visible blur. Sometimes with up to 4 seconds it will be also ok but not always. Any longer than that and it is always blurry.
For exposures between about one quarter and two seconds I usually try both with SR off and ON and choose the best - it is a matter of choosing what is worst, the sensor drift or the real shake. The longer the lens the more likely the SR will help as the real vibration that needs to be compensated will get larger compared to the sensor drift. For more than two seconds I always switch it off and for shorter than a quarter I always switch it on unless of course I am using the 2 second delay in which case it is not possible to turn it on at all, regardless of shutter speed.
What I also seemed to notice is that the drift is much worse when the camera has just been turned on and seems to get better the longer the camera is active - maybe it self calibrates or does something of the sort (or maybe I am just imagining it).
