Originally posted by dbh I was looking at all the data embedded in the K10D PEF files I took at my nephew's birthday party and noticed some intriguing info in the manufacturer notes section. The battery capacity is in there and the first shot of the afternoon showed about 98%. Over about 2 hours I shot about 70 pictures, all using the external strobe on-camera. The last file showed about 65% battery life. Of course the camera's visible indicator showed full the whole time. As many have noticed, this indicator gives you almost no warning before you're out of juice completely.
Now I'm not saying there are 100 levels of accurate and linear battery capacity information available, but this data would seem to imply more than the 3 used in the LCD indicator!
In view of the plethora of info available at the touch of the INFO button, it sure would be nice to be able to pull up that battery capacity figure from time to time since it's in there already. It even has load vs. no-load V and % !
A custom INFO page where you get to pick your favourite fields of camera-measured data would be useful since there are others in there like voltage and temperature as well.
dbh
I will need to look into this, what program were you using to look at the EXIF data as I don't recall seeing this previously.
My reason for asking is quite simple, at present, the battery indicator shows 3 positions I will also indicate on my copy of the K10D what each indicates,
full - anywhere from 100% charge to 10 shots left
half - 10 shots before the camera stops working and
dead - self explanitory no shots left.
My concern isn't that there is 100 levels known in the camera but that there are only 2 known to the user, shoot or change the battery.
