03-07-2008, 03:48 PM   #1
ebooks4pentax's Avatar
Dedicated to all Pentax DSLR "Newbies" . Join the fun.
Too often, we forget that new Digital Single Lens Reflex (DSLR) cameras are sold every day to someone with no experience with DSLR cameras at all. Whoever we are and however good we are, we started somewhere. So I decided to dedicate the next few posts to the "Newbies", the entry-lever photographers, the shooters upgrading from a point-and-shoot camera, etc. Let's go back to the basics of photography.
This post will not make you an expert in photography alone. Like any other skill we learn, practice is what makes us excel in any of our undertakings. There are many books on photo techniques on the market that you can get to further learn the craft or art of photography. For years, Kodak has regularly publish updated books targeted to beginners all the way on up to the professional photographers. Of course, lots of information is also available on the internet.
Photography, is about light. It’s about light reaching a media, film or digital sensor, and turning the results into an image that we can see, on a computer screen for example, or print on paper.
Other than the lighting conditions of a scene, there are three major items that directly affect how the light reaches the recording media. The Aperture (lens opening), the shutter speed (the speed at which the shutter opens and closes) and the media sensitivity also known as ISO number (the amount of light recording on the media for a given exposure). Too much light reaching the media, and the image will be washed out. Too little light reaching the media, and the image will be too dark. This is to say that the balance between these three items must be just right. Technically speaking, a large aperture will let a lot of light in, and therefore the shutter speed and/or the recording media will need to be adjusted accordingly. Let’s assume for a moment that the sensitivity is set at ISO 200 and cannot be changed. We now have to balance the aperture and shutter speed to get the correct amount of light in. An aperture of f/4 at a shutter speed of 1/125th of a second would give the same results as an aperture of f/5.6 at a shutter speed of 1/60th of a second. In other words, if you increase the aperture by one F-stop and decrease the shutter speed by one shutter step, the same amount of light would would reach the film or sensor. The difference between the two is the composition. Since we are dealing with digital single lens reflex (DSLR) cameras, from now on lets use the word “sensor” for media.
Aperture scale explained
The aperture, being the lens diaghphram opening, lets more or less light pass through the lens. The f-number (aperture opening) is proportional to the ratio between the lens focal length and aperture diameter, which is proportional to the square root of the aperture area. Big analogy but what does all that means? Well, lenses are usually marked with the F-numbers ranging from the largest aperture to the smallest aperture. For example, a typical lens could have an aperture range of f/2.8 to f/16. The lens would be marked as follow : f/ 16, f/11, f/8, f/5.6, f/4, f/2.8. In this example, the largest aperture would be f/2.8 while the smallest would be f/16. Have you noticed something a little surprising here? The larger the number is, the smaller the aperture is. You need to remember that. Furthermore, each (f-stop) number to the right lets twice the amount of light in as the (f-stop) number to its left and each (f-stop) number to the left lets half the light in as the (f-stop) number to its right. For example, f/4 lets twice as much light in as f/5.6 but only one half the light of f/2.8, and so on. One unit of increment in aperture is called a stop.
Shutter Speed scale explained
In photography, shutter speed is the length of time the shutter takes to open and close. The total exposure is proportional to the duration of lighr reaching the imaage sensor. Similarly to the aperture, a standardized 2:1 scale was adopted for shutter speed so that opening one aperture f-stop and reducing the shutter speed by one step resulted in the identical exposure. The agreed standards for shutter speeds are typically 1 sec,1/2 sec, 1/4 sec, 1/8 sec, 1/15 sec, 1/30 sec, 1/60 sec, 1/125 sec, 1/250 sec, 1/500 ses, 1/1000 sec, etc. A shutter speed of 1/125 sec lets twice as much light in as a shutter speed of 1/250 sec, but half the light of a shutter speed of 1/60 sec. For example, combining aperture and shutter speed, a shutter speed of 1/125 sec with an aperture of f/16 is equivalent to a shutter speed of 1/250 sec and an aperture of f/8. Alternatively, a shutter speed of 1/125 sec with an aperture of f/16 is also equivalent to a shutter speed of 1/60 sec with an aperture of f/22. Remember that one unit of increment in shutter speed is called a step.
ISO Value scale explained
Similarly to the aperture and shutter speed, the ISO linear scale, which corresponds to the older ASA scale, is 2:1. Doubling the speed of a film implies doubling the numeric value that designates the film speed. Here again, a film rated at 200 ASA or ISO 200 will absorb half of the light of a 400 ASA or ISO 400 film, but twice as much light of a 100 ASA or ISO 100 film. In the digital world, the sensitivity defines ISO speed in terms of the amount of light needed to achieve a certain quality in the sense of a per-pixel signal-to-noise ratio. The image sensors in digital cameras can be adjusted, or can have their outputs adjusted, in sensitivity to function with metering at any given comparative ISO setting. This is usually done by simply amplifying the output of the image sensor, which increases image noise, sometimes beyond the level that the ISO standard says is acceptable. Just as with photographic film, greater sensitivity comes with some loss of image quality, visible as image noise. What does that mean for you? The lower the ISO value on your digital camera, the less noise you will have and therefore, your image will appear clearer. ISO 200 is twice as sensitive to light as ISO 100 but half of ISO 400.
Next post...Combining all three elements.
Thanks for reading,
All the experienced photographers out there, let's help the new entry-level photographers. Leave your helpfull comments.
Yvon Bourque Pentax DSLRs
03-07-2008, 04:14 PM   #2
PentaxPoke's Avatar
Nice summary Yvon. And to those same newbies, get yourself a copy of Yvon's book for your camera model. They are excellent, and written by a true Pentax enthusiast.
This was not a paid endorsement, but an opinion from another Pentax enthusiast.
03-07-2008, 04:23 PM   #3
cardinal43's Avatar
I agree with PentaxPoke about the books. I have mine for the K100D, although it is pretty well marked up now by the "highlighter".
03-07-2008, 04:25 PM   #4
ve2vfd's Avatar
I agree, got the book and regularely refer to it...
Pat
03-08-2008, 12:12 AM   #5
Arpe's Avatar
An easy (for me) way to remember the the f stops is to realise that one stop is different to its neighbour by the square root of 2 (as it's related to area of the aperture) then rounded, which is about 1.4. So starting at 1-
1 x 1.4 = 1.4
1.4 x 1.4 =2
2 x 1.4 = 2.8
2.8 x 1.4 = 4
4 x 1.4 = 5.6
5.6 x 1.4 = 8 (remember, these are rounded)
etc.
03-08-2008, 12:34 AM   #6
QuoteOriginally posted by k10dbook Quote
What's the difference in these examples? Is one right & the other wrong, or are they exactly the same, or would each give different views/details/focus-points in the same photo? This is what drives me nuts the most.....
03-08-2008, 12:40 AM   #7
Arpe's Avatar
They give the same exposure, but not the same photo.
A smaller aperture (higher number) means you have greater depth of field (DOF), meaning MORE will be in focus in front of, and behind, your focus point.
So for portraits, it's generally preferred to use a bigger aperture (smaller number) to make the background out of focus, say f2. For landscapes, where you want as much as possible to be in focus, usually, you might use f16.
03-08-2008, 01:23 AM   #8
QuoteOriginally posted by arthur pappas Quote
Arpe is correct in his answer above.
The difference is the depth of field for the apeerture and of course, the faster the shutter speed, more movement is permitted without being blurred. I will let everyone learning the Aperture/Shutter speed and Sensitivity (ISO) have some time to digest the above post. I will then post how to put these three elements together in order to compose your image for the effect you really want.
Regards,
Yvon Bourque
03-08-2008, 07:49 AM   #9
krs
QuoteOriginally posted by desame.one Quote
An even easier way is to just double up every other number: 1, 1.4, 2, 2.8, 4, 5.6, 8, 11, 16, 22, 32
I like this one. Part of my problem is keeping the "standard" stops straight from the 1/2 stops or 1/3 stops.
03-09-2008, 12:48 PM   #10
axl
so now f4 is full stop from f2.8, right? At the beginning I thought full stop up would be f5.6, and considered f4 as a half stop. I see I was wrong... Quick test on my cam cofirmed...
Good thread, hopefully there will be more like this...
03-09-2008, 04:16 PM   #11
Arpe's Avatar
QuoteOriginally posted by krs Quote
Every second one doubles because you have multiplied by √2 twice, so √2 x √2 = 2!
03-09-2008, 07:07 PM   #12
krs
QuoteOriginally posted by Arpe Quote
That is multiplied by 2 or 2! (2 factorial, which is 2*1)
Sorry - could not resist!
03-10-2008, 06:37 PM   #13
clawhammer's Avatar
*head bursting from use of advanced math*
aperture, camera, dslr, film, image, iso, lens, light, media, photography, scale, sec, shutter
Misc P52 "Pattern" notification: join in! Rense Post Your Photos! 4 05-16-2010 02:59 AM
DSLR advice from one of those "other" photo forums (also, Pentax and low-light) shuttervox Pentax DSLR Discussion 38 02-25-2009 05:50 PM
Join in the National and Local "I am" Series daacon Post Your Photos! 17 11-25-2008 06:46 AM
PART 2...Dedicated to all Pentax DSLR "Newbies" . Join the fun. ebooks4pentax Pentax DSLR Discussion 14 03-11-2008 08:33 AM
New Pentax "Brighten Your Holidays" DSLR rebates start October 18! aerodave Pentax News and Rumors 21 10-19-2007 02:51 PM
All times are GMT -7. The time now is 04:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
