Originally posted by kkoether Hope you don't mind. I ran your picture through Aftershot Pro and as Alfie suggested I set the white balance off of the guys gray cap. Definitely a white balance issue. I'd say the reds and greens where screwing up the AWB setting. Here is the corrected image.
That is far too yellow. On my calibrated monitor it needed backing off just a touch on the blue, just enough so that the almost burn-out sky doesn't turn yellow. And a small brightness tweak to lighten up the shadows, maybe. The camera WB wasn't far off actually. You could do much more if the file was RAW
