03-09-2008, 07:31 PM   #1
KungPOW's Avatar
How to set Shake Reduction with macro lenses?
I have a set of macro lenses that screw onto the front of my M series lenses, allowing them to be used for closeup photography. Not quite macro, but close enough for me for now.
They are a set of three, numbered 1,2 and 3. I have used them alone, and combined.
How do I set the shake reduction? Say I am using a 50mm lens, is the shake reduction still set to 50mm? Or, should I just turn it off?
Thanks for your help!
Eric
03-09-2008, 11:18 PM   #2
Big Dave's Avatar
Eric,
Set SR for the focal lenght of the lens. Those suplimental lenses don't change the focal lenght. they only reduce the working distance, allow closer focusing.
Dave
03-09-2008, 11:45 PM   #3
Eric, Dave is right, but the classic rule of close-up photography is righter: use a tripod or other support! Then, of course, you won't need SR and you'll get the sharpest possible result out of either macro lenses or close-up diopters.
03-10-2008, 08:28 AM   #4
Big Dave's Avatar
Eric,
I forgot to mention that the closeup lenses come in different diopters to change the mag ratio.
Dave
03-10-2008, 05:45 PM   #5
KungPOW's Avatar
Thanks for the info!
So, closeup lenses don't change the focal length, and I should be using a tripod.
Eric.
03-10-2008, 07:52 PM   #6
Stratman's Avatar
And if you are using a tripod, you shouldn't use shake reduction, and you shouldn't need it.
03-10-2008, 08:15 PM   #7
Miserere's Avatar
I'll just go ahead and disagree with everyone, or maybe not. If the close-up lens reduces your field of view (i.e., magnifies the image), then you should modify the focal length you set on the SR accordingly; if it simply allows you to focus closer, then you should be OK not changing anything.
50mm, camera, dslr, lenses, macro, photography, reduction, shake, shake reduction
K-x shake reduction with non-Pentax Zoom lenses JoepLX3 Pentax DSLR Discussion 12 08-21-2010 11:41 AM
Trying to set the lens mm for shake reduction gary1952 Pentax DSLR Discussion 26 07-14-2010 02:32 PM
Shake Reduction with internal focus lenses pa79 Pentax DSLR Discussion 14 03-31-2009 04:13 PM
Shake reduction setting for macro Nick Siebers Photographic Technique 30 03-09-2009 08:15 AM
Right focal lenght for shake reduction on s-mount lenses uPiX Pentax SLR Lens Discussion 13 01-31-2008 07:39 AM
All times are GMT -7. The time now is 10:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
