Originally posted by haycyn So I have acquired a few different lenses. Can I have a recommendation of which one to use in an upcoming situation like this one?
DA-15mm limited.
70-200 sigma 2.8
Pentax 100mm WR 2.8.
I'm headed to the site in a bit to take some test shots.
In another life (when I used Canon) I used a Tokina 50-135 f2.8 to shoot Muscle/Body Building shows. Because in event photography you never really know where you will be standing or where they will put you, a zoom lens is your best choice. Also a zoom with a constant aperature is preferred. Not knowing your budget but from what I have read about Pentax lenses I would suggest the 16-45 F4 and the 50-135 f2.8. If you are using flash, then the 18-135 may be perfect for your needs.
A side note about the kids. I realize the instinct of a mother is to have your children with you. But if you want to do event photography seriously and you must bring the little ones... bring a teenager with you or a friend to keep an eye on the little ones so that YOU can keep an eye on the event. Event photography is very much about capturing a moment! You already have too much to pay attention to! Please no hate mail! LOL! I am a father and grandfather...
Lastly it's not the gear you use... although it helps... but you don't need $1600 lenses to make a living in photography! You do need good gear and you need to research the gear before buying it... there was a lot of good information in this thread... you just need to dissect the parts that pertain to you and implement them to your abilities and interests! Best of luck!
