03-10-2008, 05:30 PM   #1
owner's name change in the K10D
I bought my K10d used, and I still see the owners name in the exif of my pictures. Is there a way to change the owner's name?
Thanks
03-10-2008, 07:48 PM   #2
Stratman's Avatar
Hm, interesting, I had no idea you could put your name in the exif !! If anyone knows how, please explain
03-10-2008, 10:04 PM   #3
You can do that? Dang, that makes copyrighting an image a little easier...
03-10-2008, 10:12 PM   #4
WMBP's Avatar
QuoteOriginally posted by Spaceguy1 Quote
Add me to the list of those who were not aware that this was even possible. I add all of this info to my photos in post-processing.
Are you sure this is happening in the camera?
Will
03-10-2008, 10:24 PM   #5
Somebody must be a better hacker than any of us.
03-10-2008, 10:38 PM   #6
I'd sure like to know how to do that with both the K100D, and the Sigma SD14
That would sure make copyrighting easier.
03-10-2008, 10:41 PM   #7
Canada_Rockies's Avatar
Thanks
Is this after you import it into Pentax Browser? If so, the change can be made in the browser. You might be able to change it in the browser even if that is not where it is designated. I use Lightroom, and there is a whole copyright section that you can set to default when the image is imported from the camera.
03-10-2008, 11:06 PM   #8
Hi guys,
It's after I import it on to Lightroom.
I know you can do this with the Canon models, and I thought you can do the same with the pentax bodies, but I just don't know where. Unless that www.marszifheifhcino.com is normal???
03-10-2008, 11:35 PM   #9
That link is broken Spaceguy,
Here's the real one.
If you can understand whatever language the site is in it might be a good place for an answer.
If not why not just write to the owner, if you bought it from them off this board or another one.
Please be sure to post the answer.
A friend of mine is looking into programing his own versions of firmware. I wonder if I can get him to program that data in as well
03-11-2008, 12:00 AM   #10
distudio's Avatar
Hi guys,
Someone has likely flashed it with modified firmware, see:
pentax-faq blog - archiwum
Just install firmware upgrade from the Pentax site and it should revert to normal.
03-11-2008, 01:52 AM   #11
ftpaddict's Avatar
Ack, it's in Polish.
03-11-2008, 05:47 AM   #12
stewart_photo's Avatar
Hi guys,
It's after I import it on to Lightroom. (snip)
Interesting. It's somehow replacing the camera make with a personal entry. Since there is no simple/known way to do that within the Pentax camera, I agree with the others suggesting the computer software (in this case, Lightroom). Look carefully through your Lightroom preference menus for anything matching that URL and delete it. If you can't find it, delete the Lightroom preference files outright. In the process, replace/reinstall the camera's firmware.
Afterwards, if none of above worked, I would be looking into the possibility that someone has hacked into the computer's files. This URL alone is certainly not proof of that, but any unusual behavior such as this deserves further investigation. Checking for spyware/virus activity is a good place to start with that investigation.
stewart
03-11-2008, 06:09 AM   #13
Yes, the link was to a page in Polish. It looks like this site has firmware with Polish menu options. I do not have K10D so I do not know, but if Polish is not one of the standard languages, then the firmware is most likely hacked. That would explain the link in EXIF info. I guess hacker left his/hers signature.
If you need anything translated from Polish, let me know :-)
03-11-2008, 07:01 AM   #14
WMBP's Avatar
Now I'm really confused. What did you buy used from the other fellow--the camera, or the camera + the software? Even if you bought the software, too, you'd almost have to have purchased his computer, too, because the metadata prefs must be stored in a prefs file somewhere, not in the app.
Will
03-11-2008, 07:14 AM   #15
Gooshin's Avatar
QuoteOriginally posted by FireMate Quote
except that changing the exif is just as easy...
camera, change, dslr, k10d, name, name change, photography
new K10d Owner kmanlaker Pentax DSLR Discussion 10 07-10-2008 04:44 AM
Change K10D for 'RAW' shooting dales Photographic Technique 2 02-07-2008 12:51 PM
K10D won't change for 'RAW' shooting dales Pentax DSLR Discussion 4 12-30-2007 09:11 AM
New K10D owner here dwinnert Welcomes and Introductions 11 05-19-2007 08:44 AM
Soon to be K10d owner! Quaffle Welcomes and Introductions 5 12-26-2006 08:46 AM
All times are GMT -7. The time now is 07:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
