03-15-2008, 04:38 AM   #16
KjetilH's Avatar
QuoteOriginally posted by kevinfox203 Quote
Ok, so I followed the 'step-by-step instructions' and I've hit a roadblock. Please help.
screen reads:
WAIT HS...
DSP ver: 1.00.00.07
CPU ver: 1:00.00.07
PRG 620 256 256 398
How do I get out of here and back to normal???
You got a step-by-step PM.
03-15-2008, 05:40 PM   #17
How do I get out of this mode now?
03-15-2008, 05:52 PM   #18
KjetilH's Avatar
Sorry for not being telepathic (what 'mode'?), but I guess you don't want the camera to be in debug mode forever:
Turn off the camera.
Hold AE-L and INFO while turning the camera ON.
Then press MENU, MENU, INFO.
Highlight DEBUG MODE, and set it to DIS (disabled) instead of EN (enabled).
Press OK.
03-15-2008, 05:56 PM   #19
Thanks KjetilH!
03-15-2008, 08:44 PM   #20
jdg
jdg's Avatar
Can you calibrate the AF with this service menu on the k100d super?
03-16-2008, 03:51 AM   #21
KjetilH's Avatar
I have not exactly tried it, but the debug mode has an option for AF.
03-16-2008, 07:29 AM   #22
QuoteOriginally posted by Finger Quote
neither on mine, maybe just on the non super k100d ...
Pentax had changed the sequence intentionally for newer cameras or newer firmwares to avoid users to get into the engineering mode anymore.
03-16-2008, 07:35 AM   #23
QuoteOriginally posted by KjetilH Quote
I noticed a guide for checking the number of pictures taken, which made use of the service menu, and was wondering about what all the options in the service menu actually do.
Holding INFO and AE-L while turning on the camera.
Quickly after, press MENU, MENU, INFO.
Here are some of the screen captures for the secret mode:-
RiceHigh's Pentax Blog: Screen Captures of the Secret Mode of the K100D
"WRITE CF VNDR" - ???
To enter the memory card chipset vendor.
"SCRIPT EN MODE" - ???
Scripting Enable Mode
"USR DAT CLEAR" - ???
Clear all user stored data
"RELEASE AGING" - Just making the camera shutter go berserk. Nothing useful, I guess.
Nope. It's useful to check the healthiness of shutter and mirror mehanics by firing continuous for the shutter (and the mirror) alone.
"LENS COM CHECK" - From the name, I guess it is for testing A lenses.
Lens communication test.
I am just a bit curious, what do the other things mean?
Well, I think the most useful thing is to adjust the BF and FF of the AF by entering the debug mode by setting it to EN (Enabled).
03-23-2008, 10:20 PM   #24
OniFactor's Avatar
RH, do you know how they label the AF points? which is which?
03-23-2008, 10:53 PM   #25
jgredline's Avatar
According to PhotoMe, my K110D has over 30,000 shutter actuations...Works as great as the day it was new...
03-24-2008, 06:12 AM   #26
Gooshin's Avatar
QuoteOriginally posted by jgredline Quote
because you can tell the difference between a 1/1000 shutter speed and a 1/4000 shutter speed with your eyes and ears alone...
camera, dslr, info, menu, options, photography, pictures, press, service, shutter
K100d Super Debug Menu Instructions rmtschanz Pentax DSLR Discussion 5 04-28-2010 06:16 AM
k100d Super Service Menu ChiZach Pentax DSLR Discussion 6 08-23-2009 03:53 PM
K10D Service Menu and AF Adjust! nosnoop Pentax DSLR Discussion 54 12-08-2008 02:49 PM
K100D Menu tux08902 Pentax DSLR Discussion 6 11-25-2007 10:06 AM
K100D Super Debug menu joelw135 Pentax DSLR Discussion 9 10-18-2007 04:23 AM
All times are GMT -7. The time now is 12:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
