01-11-2007, 08:19 PM   #1
Cropping by mm
I took some photos with my 43mm lens that need to be taken with a longer lens. I plan on returning to the same location this weekend and have been trying to figure out what the best focal length would be best to use. There must be a way to put a photo from a 43 mm lens in photoshop and crop it to a certain percentage so I can see what that scene would look like if shot with a 135mm lens, or any other lens.
I know I am not making myself clear. Hope one of you understands what I am trying to do.
Thanks for any ideas you could give me.
01-11-2007, 09:05 PM   #2
u would need to crop an then enlarge.. possible but i am not sure on how to arrive at the exact size factor thow.. the enlarge is easy but getting the crop right might be awkward..
trog
01-11-2007, 09:09 PM   #3
jfdavis58's Avatar
Trigonometry and the camera to subject distance. You can use a right triangle and approximate to a fair degree of accuracy OR use half the width/height, 1/2 the angle of view and that same right triangle for a precise answer.
01-11-2007, 11:10 PM   #4
SpecialK's Avatar
How about ... 43/FL (FL = focal length of other lens) X # of pixels in width of original shot. Then crop out from center 1/2 of that number each direction. Enlarge FL/43 to get back to original display size.
I have no clue what the PS commands are for that:-)
camera, dslr, lens, mm, photography
Photo cropping and editing. natimmas Pentax DSLR Discussion 8 09-01-2010 05:04 AM
Do you use a Standard when Cropping for Print? hockmasm Digital Processing, Software, and Printing 7 05-11-2010 06:36 AM
K-x cropping question dehanson1 Troubleshooting and Beginner Help 4 05-06-2010 03:13 PM
Cropping a DA 15mm Tests merengue Pentax SLR Lens Discussion 4 12-14-2009 01:42 PM
A question of cropping FHPhotographer Digital Processing, Software, and Printing 5 10-26-2009 08:08 PM
All times are GMT -7. The time now is 09:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
