06-03-2013, 06:51 PM   #1
Bcrary3's Avatar
K5 white balance?
I'm trying to use a piece of welding glass (shade 10) as an ND filter, however it has a very green tint to it, and every time I try to adjust my custom WB mode, it doesn't seem to correct the colour. And when I go into the menu WB>WB manual > WB Manual 3 > Manual WB (where it gives you the option that says SHUTTER ADJUST) and I compose a shot to I get an error The operation could not be completed correctly. Anyone know what is going on here or how to fix it? I've had no problem setting custom white balance in the past... Please help as this is time sensitive. Thanks in advance!
06-04-2013, 12:05 AM   #2
adwb's Avatar
No I don't which does not help. All I can add is that trying the same thing with various colours on gels that ome times it works and some times not. I have the impression it depends on how mich light actually gets through which is why ,I suspect, your dark welding. Glass won't work.
camera, custom, dslr, photography, time, wb
K5 with DA*300 white balance derekkite Pentax K-5 7 01-25-2013 02:32 AM
Setting custom white balance in K5 TylerD Pentax K-5 0 06-16-2012 12:39 PM
K5 flash white balance adwb Flashes, Lighting, and Studio 5 02-17-2012 04:07 PM
Manual white balance problems on K5 2grahamb Pentax K-5 10 09-29-2011 01:06 AM
Auto white balance vs. daylight balance outdoors. fevbusch Pentax DSLR Discussion 7 02-18-2007 03:04 PM
All times are GMT -7. The time now is 06:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
