Originally posted by VHDEL Is it possible to reset the IMG count on the K20D so it properly reflects the actual shutter actuations shown in PhotoMe?
Cheers
Del
From memory; there is a menu option to either take the number from the inserted card or to remember that last one used.
1. Take a shot and rename it to the number you want on your PC.
2. Set the menu to take the number from the card
3. Insert the card in the camera and take a shot
4. Set the menu to remember the card No.
5. Clear the card and you should be away..
EDIT: I just tried this and it worked. The menu item is "File No." under "Rec Mode" -> "Memory".
day
