06-14-2013, 11:43 PM   #1
brandonbpm's Avatar
DIY Macro shoot
I apologize if this has been discussed or shown before, but I wanted to share it with you all. I can be a very impulsive person, and a very impatient person at times too, so earlier tonight when I wanted to try some macro photography for the first time, I wanted it NOW. I didn't want to have to wait to order extension tubes or reversing adapting rings and for them to come next week before I did.
So I took my Pentax-M 50mm f1.7, reversed it and duct taped it to the end of my 18-55mm kit lens. I focused the 1.7 to infinity before taping it, and afterwards made sure the aperture was wide open. I initally had it taped to my 50-200mm, but in order to minimalize the vignetting/pinhole effect, the lens had to be zoomed in all the way at 200mm the magnification was TOO large for my subjects, so instead I switched and taped the 50 1.7 to the 18-55 kit and zoomed to 55mm and it was a good magnifaction. I threw on a speedlight and bounced it either off the ceiling or on the pullout bounce card (when I was outdoors) and shot away. You can still adjust depth of field with the on camera lens aperture settings (i didnt figure this out until the end of my shooting) and using the flash helped to freeze the subject to avoid blurring (camera shake is inevitable handheld at these magnifications)
So I got some pretty good results for macro shots handheld without buying any new equipment. Just used my K20D, 2 lenses, speedlight and duct tape.
06-14-2013, 11:59 PM   #2
TZH
TZH's Avatar
Pretty good result, how many f-stop?
06-15-2013, 03:02 AM   #3
Excellent result but the image you painted of yourself just cracks me up lol
06-15-2013, 07:00 AM   #4
JimJohnson's Avatar
Location: Summer:Lake Superior - Michigan Winter:Texas Hill Country
cool!
By the way, pre-focusing the reversed lens to infinity is meaningless in terms of altering focusing distance. When mounted normally, focusing the lens moves the optical elements closer or further from the image plane. However in reverse mode, all you are doing is moving the lens barrel, not the optical elements. In fact, when moving a reversed lens to its closest focusing point, the lens barrel forms a hood to reduce flare.
Duct tape works, but if you are going to do this regularly, it is worth the cost to purchase a male to male filter thread adapter to more firmly and accurately attach the two lenses. If necessary, you can add a step ring to accommodate two different filter thread diameters.
06-15-2013, 10:25 AM   #5
brandonbpm's Avatar
Thanks guys! I love learning more and more everyday, and I definitely plan to invest in some of those adapter rings. This experiment was very fun and worth re-visiting.
Also, I honestly couldnt tell you the F-stop, it was wide open for most (f4.5) but once I found out that the on-camera lens aperture still affects depth of field I experimented later on down to f8 and f9 on some
06-15-2013, 11:52 AM   #6
That is just plain fun, learning through experimenting! And ending up with nice results, of course. I have quite same issue myself, have an idea -> test it, not now but right away! I had a DIY extension ring on my Oly, and i think i will make somekind of macrothingie with these K-mount lenses. Just waiting for inspiration...
06-17-2013, 12:48 AM   #7
Nice picture. and Great Narration
aperture, camera, diy macro, dslr, duct, flickr, kit, lens, macro, person, photography
DIY Odd Pod for Macro and Lightbox DeepThrob Do-It-Yourself 6 04-14-2015 03:15 PM
Macro Some more DIY Macro shots Stoogie Post Your Photos! 9 09-12-2012 12:36 AM
Macro DIY Macro Setup jaieger Post Your Photos! 5 11-08-2010 05:12 PM
DIY macro tripod wildman Pentax Camera and Field Accessories 4 04-14-2009 09:07 AM
Cheap DIY macro lens! ftpaddict Pentax SLR Lens Discussion 9 11-25-2008 01:00 AM
All times are GMT -7. The time now is 08:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
