03-14-2008, 10:19 PM   #1
pentagor's Avatar
ISO warning light and K100D
Hi!
I've been searching through the forum, but didn't find anything usefull about this.
In custom menu on K100D there is a possibility to tell the camera at which ISO speed, the ISO warning light should be on n viewfinder.
Unfortunately, on my camera i doesn't work as it should. It works only, if the ISO sensitivity is set manualy.
For example: The setting in custom menu is at 2: ISO 800. As I understand, the ISO warning light should go on, if the camera raises ISO to 800 or more in case when Auto ISO is selected in Fn menu. But this is not the case. It only goes on, when I manualy set the ISO speed to 800 or more.
Is this normal for K100D, or is it something in a firmware?
Thank you for your responses.
03-14-2008, 11:41 PM   #2
Yes, it's normal. When Auto ISO is selected, the warning light won't turn on.
I believe I read that in the manual in one of the footnotes. I'll have to check that when I get home.
03-14-2008, 11:46 PM   #3
At the bottom of page 122 is a memo item which says:
ISO Sensitivity Warning is not displayed even if the automatically corrected sensitivity exceeds the set sensitivty setting.
In a roundabout way they are saying the warning does not work when Auto ISO is chosen.
Rusty
03-15-2008, 12:03 AM   #4
pentagor's Avatar
QuoteOriginally posted by Rusty Quote
Rusty
Well.... I don't need a warning, when I manually set the ISO. If I do that, then I have a control over it, and I know what value I selected.
I need a warning, when the camera changes ISO for me. Doesn't that make sense?
Something strange going on in the heads of firmware designers/programmers, or is it me with strange requests?
03-15-2008, 12:09 AM   #5
It's in case you manually exceed what you previously determined was the maximum ISO you wanted to shot at. In Auto ISO you can set the range so that your predetermined maximum is not exceeded - hence no warning necessary.
Makes sense to me :-)
Rusty
03-15-2008, 12:12 AM   #6
pentagor's Avatar
That's the other way to see it
03-15-2008, 04:54 AM   #7
mattdm's Avatar
QuoteOriginally posted by pentagor Quote
I agree, it's pretty pointless. I too would prefer what you're suggesting.
03-15-2008, 05:05 AM   #8
I think the warning system as it is now is meant to warn you when you forget that you set the ISO manually to a high value while shooting something else (maybe even days ago).
03-15-2008, 09:08 AM   #9
pentagor's Avatar
Now, it doesn't matter the ISO warning. Thanks everyone...
My K100D just dropped dead. The mirror doesn't move at all.
With totally fresh batteries it makes a photo, but no more than one. Even this one mirror reflex is somehow strange... Like it would hardly move the mirror.
Well, it's under warranty, so on Monday it goes to repair. I just hope not to be without it for a very long time....
camera, custom, dslr, iso, k100d, light, menu, photography
K-5 low light/High ISO samples johnmflores Pentax K-5 21 04-19-2011 05:03 PM
Help with KX, Low Light, and High ISO dmfw Troubleshooting and Beginner Help 7 04-01-2010 11:38 PM
Pentax K-x Shutter Speed, ISO, Low Light.. jbarcus81 Pentax DSLR Discussion 4 02-14-2010 07:26 AM
K200D low light/high iso performance indytax Pentax DSLR Discussion 22 02-07-2009 07:49 PM
Tests iso 200 to iso 3200 with k100d Deni Post Your Photos! 0 06-20-2007 05:17 AM
All times are GMT -7. The time now is 08:16 PM. | See also: NikonForums.com, part of our network of photo forums!
