Hello,
I need your kind help to decide which camera I should go for. Today I have a K100D with various lenses, 16-45 sees a lot of action, 55-300 in the good days, 50 1.4 is next on line and last but not least is be the Tamron 28-75. When I build up this line I was thinking it will work in low light of Sweden. Latest experience tells, it does not work when in equation comes indoors, north facing windows, and the subject I try to get is my toddler daughter that when she sees the camera runs to get it. When the flash is mounted the little fingers cannot stop fiddling with the green and red lights until I put it away.
Yesterday she was playing nicely with her new train indoors and I wanted to get a photo. Did not work out but instead I managed to distract her. I set the ISO to 1600 with the aperture of 2.8 I got the TV to be 8 for a correct exposed shot. Too low for a child that when heard the first clack was up and running to get the camera and take pictures and see what I did. Thought of changing to 50mm with f2. Quick calculation told me not to do it, that would have improved the speed just marginally and could not solve my problem, @ f2 I would get TV 16 - too slow for a fast moving molecule, and 50 is narrow for indoors.
Calculation wise: ISO @ 128000 - > TV – 125 - decent enough to freeze some action. Underexpose one stop and I get to Tv @ 250 - this sound more like a freezing number.
In Sweden there is Pentax cash back program for K5 II and IIs and K30. The K30 is now ridiculously low price of 4500SEK with the 18-55 DAL lens. The lens kit is non WR and will end up unused. The body only after cash back will be slightly more expensive but must go through the hassle of cash back. The K30 and 18-135 will be down to 7300SEK after rebate and I would like to have that lens for diversity. What do not like the lens is that is very slow at 135mm where I would like to use it. For these I use the Takumar 135mm wide open and it works.
Cashback Sommarkampanj 2013 - PENTAX Photo
Thinking about the conditions of low light brought K5IIs in the equation that have faster low light focus, 14bit raw – I see it useful to reduce the noise and retain details during post processing in case I underexpose, higher dynamic range without fiddling with the menus, one stop in ISO and silent shutter! It does not have focus peaking though for when I use manual lenses. The price is in another league though. In this case I would choose only the body and still will be more expensive that K30 and 18-135mm kit. On the good part there is also the top LCD that helped me a lot while in the K100D the viewfinder notifications are small and difficult to check.
What way should I go?
1. I lean toward the K5 IIs but I have no WR lens - I will not feel comfortable to take it out in bad weather and here is more bad weather than good one... More, leaving 1kg object worth 10k+ into the small hands that mimic everything the father is doing with the camera: lift camera to the eye site, try to carry it around, try to put it around the neck and so on is not comforting.
2. K30 kit with non WR lens - could make sense only when I decide to sell it with a lens attached.
3. K30 with 18-135 - this will be possible to use it outside in bad weather. The bad is that the lens is rather slow.
All advices are welcomed!
