Originally posted by jfdavis58 Hi, jumping in here with my results.
Wein safe Sync does NOT seem to work with my K10 and standard PC triggered flash-any mode setting. I did try removing the safe sync and shorting the contacts with one lead of my VOM-POP, flash did fire, cable and sync do work.
Seems that until we get some notion of the signals present on the Pentax hotshoe/K10, that we are stuck with proprietary flashes and perhaps the Sigma unit.
PTTL preflash triggers all my photon based slaves pre shutter--also useless.
I do not have a safe sync, so I cannot comment on the operation of that device. However, I just shot about 50 studio portraits yesterday with my K10d using my Chinese radio slave as I always do.
I put the little sender into the hotshoe of the K10D (the sender has only a center pin, which, as far as I know is simply a flash triger signal only on all Pentax bodies), put the receiver into my H-Prong to 1/4" adapter cable and then into the Lumedyne I was using as a hairlight, and then let the monolights all trip off the optical slaves.
I shoot in M mode, and the flashes all syncronized just fine up to the max of 1/180 at whatever aperture I was using.
I move the radio receiver around to set each light independently, and it tripped them all just fine from the hotshoe of the K10D just as it does on my K100 and DS bodies.
Over at DPreview, some were having trouble when using X sync and radio slaves and studio lights, but they seemed to have more success when using M mode instead of x sync. You might try that.
This week, I also modified 2 Nikon Speedlights, (model 25) to remove the Nikon TTL pins from the foot (VERY simple to do if you have a decent soldering iron), leaving only the center pin, and they work perfectly in auto and manual mode on all of my Pentax bodies. No P-TTL, but I hate the pre-flash anyway and find auto to be more reliable.
Ray
