Originally posted by sharpshoota pocket wizards, definitely.
Overkill for someone who is just starting.
I'd suggest either Poverty Wizards (a nickname for the YinHe "Cactus" triggers available from Gadget Infinity, Link Delight, and a few other eBay vendors) or the new AlienBees CyberSyncs.
The Bees are a good middle ground in price/performance between Poverty Wizards and Pocket Wizards. I only own some Poverty Wizards currently but will be replacing them with CyberSyncs soon.
The CyberSyncs apparently have much greater reliability than the Cacti and somewhat improved range, but not the insane range of the Pocket Wizards. (but not the insane price either).
Reading through the thread:
1) Someone said the sync voltage limit for the K10D is 6 volts. That's the voltage limit for Canons. Someone got a response from a Pentax rep that it was at least 30 volts
2) Ben took a huge risk putting 200v directly into his hotshoe without a Safe-Sync or similar device. The K10D's hotshoe must be far more robust than specified if his K10D survived.
Most if not all of the receivers for any of the radio flash trigger systems can handle the trigger voltage of any flash, old (hundreds) or new (6-12 volts). A few have problems with ultra-low-voltage flashs (some Cacti don't work with the Vivitar 285HV, Pentax AF-540, and most new Canon flashes).
