03-24-2008, 08:26 AM   #16
proudtoshootpentax's Avatar
I'm still sticking with the FGZ 360 recommendation. You can use it in fully manual mode just as the Nikon, and it has the same output, so there's no loss in power. You can set it to slave manually without having to use P-TTl, and when you grow into your system, and want to get more creative, you'll have a flash that is capable of doing everything your SB 24 could have and much much more. As far as a swivel head... wireless P-TTL means you can take the flash off the camera and point it wherever your little heart desires!
03-24-2008, 10:34 AM   #17
Slightly different question
I own a K100D, and also am looking for an external flash system on a student budget. Will the aforementioned recommendations work equally as well, or must I stick with the 360 or 540 Pentaxes? In particular, I'd like to try off-camera wireless flash, but I don't recall seeing such a setting on the K100D.
To be honest, most of the places I shoot (concerts, indoor candids) are best served with fast lenses, so I've simply used my on-camera flash for now, and am saving up for the tamron 17-50. But this thread has got me thinking. Any recommendations?
03-24-2008, 11:18 AM   #18
Do.
Not.
Under.
Any.
Circumstances.
Get.
A.
Sigma.
Flash.
Unit.
04-06-2008, 08:51 AM   #19
skydragoness's Avatar
Soo...
I got my SB-24 in the mail from KEH. Fantastic condition and I got a little instruction booklet for it too.
However, I noticed it only works on my camera in Wireless Flash mode. Is that right? How come it doesn't work in regular flash mode? Does this mean they are not "talking" to each other fully?
In my photo class people with Canon's and Nikon's tried it on and the SB-24 all worked for them without them having to change any menu functions, but when it was on my K10, it did not fire until I switched the flash function to Wireless mode..what's up with that? Will this inhibit any control I may have on it? Does it have to do with it not being P-TTL?
04-06-2008, 10:09 AM   #20
ryan s's Avatar
Just double checked mine...works fine in M and X sync. I never messed with the flash menu, so it's set like stock.
Is your flash set on M? The slider on the top right on the unit...
04-06-2008, 02:52 PM   #21
QuoteOriginally posted by ryan s Quote
Yeah it was set in M.
Ok, this is weird, it's working in regular flash mode, red-eye flash, and wireless. The night before in class it didn't do crap.
Ok, I know why now: before the flash was put on it was in Trail-Curtain Sync mode. The flash won't fire in that mode.
So I found the buttons on the SB-24, for rear curtain, TTL, the three little bolts , and the A will only function in X sync mode? In M mode, the flash only fires if I set in the three modes I mentioned above. Okay, I understand now. I was upset at first thinking something was wrong! Derkader. Well I'll be having fun with this .. this flash is powerful! ( Now I have to get used to the high pitched bomb-about-to-go-off sound a flash makes).
04-06-2008, 05:16 PM   #22
ryan s's Avatar
Good that it's figured out
It does make some interesting sounds...and the front gets pretty hot when it goes off...
04-07-2008, 09:47 AM   #23
DHCowboy's Avatar
I used my SB 24 on the K10 for a number of weeks and through one wedding, - no ill effects. Same went for the SB 20. (only no swivel head)
All of the Nikon flashes I have heard, are of low voltage at the shoe. And the build quality, as has already been mentioned, is sub-par to none.
BTW, - I 1st purchased the Sigma DGSuper for the K10 and detested it's controls and the build. Sent it home and got the FGZ 540. Much happier and now the Nikon units have been relegated to the Nikon bad of tricks for a D70 I picked up cheap...
Cheers and happy-snappin'!
04-07-2008, 01:17 PM   #24
rear/trailing curtain and HSS/FP mode requires a matching flash.
You're basically using it as a non-dedicated flash, so you have two options for use:
- full manual where you set the power level
- auto-thyristor mode where you tell the flash what f-stop/ISO you're using and the flash measures light to control itself
Ignore all the other features on your SB-24. They won't work on your K10D.
Google up "strobist" and let the learning begin.
Go buy a fleabay trigger for $20 and learn how to use off-camera flash.
Learn properly and your flash photos will not suck :-)
For the price of a Pentax 540, I have 3 used Nikon flashes and a set of wireless triggers. The only weakness is when you're shooting dynamic situations where you need more than one flash (e.g., kids indoors).
04-07-2008, 01:45 PM   #25
QuoteOriginally posted by Mikhail Quote
I'd go for an old unit for offcamera flash. You prof probably doesn't want you using auto modes so dont pay for it. Get a SB-24\25, Sunpak 383, Vivitar 285HV or some other older ones.. (btw thats in order of preference personally).
Thanks
Yeah. Given that your prof reccommended the 285HV, it sounds like he is expecting one of the following:
1) You won't need TTL capabilities
or more likely
2) You won't be allowed to use TTL capabilities
I have an AF-540FGZ and a Vivitar 285HV - I find myself using the 285HV far more often, as in most situations it actually exposes more correctly than the AF-540, and it costs 1/3 the price! You can get a complete MPEX Strobist kit (light stand, umbrella, sync cables or wireless triggers) for far less than the price of an AF-540FGZ.
If you're getting the flash unit for photography classes and you're on a student budget, don't waste money on a super high end P-TTL flash. Go for a flexible auto-thyristor flash with lots of manual flexibility (Viv 285HV, Sunpak 383) - in fact for the same price as an AF-540FGZ you can get three flashes like the 285HV and 383!
04-07-2008, 04:05 PM   #26
Another recommendation to at least strongly consider the Sunpak 383.
Just tell the flash what ISO you are using and the how far the subject is from the camera, the flash will do the rest. In return, the camera will tell you what aperature to use. For the shutter speed, just set it to the highest speed that your camera could synchronize with an external flash. Only about $80.
Bob
04-07-2008, 04:06 PM   #27
Mikhail's Avatar
Um personally I wouldnt be putting a SB24 on top of my Pentax camera unless all the pins but the centre one were removed or covered up in some fashion... you may not of had any ill effects yet but who knows...
Enjoy your new toy!
Thanks
04-07-2008, 10:12 PM   #28
benplaut's Avatar
Enjoy your new toy!
Thanks
It's fine. Really. Not only are the pins in slightly different places, but the hotshoe isn't affected when its pins are shorted together. I also checked the flash with a multimeter, none of the contacts volt back on firing except for the fire pin, which is ~4v (this is on a SB-80, close enough).
YMMV
04-12-2008, 10:50 PM   #29
QuoteOriginally posted by kenyee Quote
Can someone elaborate on that? Are the Sunpack and Vivitar models recommended throughout the thread a "matching flash" ?
04-13-2008, 06:56 PM   #30
I don't know about trailing-curtain sync with non-PTTL flashes, I'd need to test that out.
HSS is only possible with P-TTL flashes, and not even all of them. (All of the Pentax models I'm fairly certain, but not necessarily the third-party ones). That said, HSS is a relatively recent and niche feature (although it sure is nice when trying to overpower ambient! But you could just tie together three Viv 285HVs for the same price and simply overpower ambient with brute force.)
Remember, high speed sync is NOT needed to stop action - in fact because it effectively increases the flash duration, it is the last thing you want if you want to stop movement.
camera, dslr, photography, sigma
Egyptian-American college student finds tracking device on car; FBI reclaims it deadwolfbones General Talk 25 10-20-2010 12:02 PM
Hello from State College CGottfried Welcomes and Introductions 3 06-19-2010 06:22 AM
College student budget 100-300mm lens? Christemo Troubleshooting and Beginner Help 24 06-16-2010 09:07 PM
K-x or other for college student? justdad Troubleshooting and Beginner Help 10 05-13-2010 11:56 AM
Calvin College IR The Pentax Hammer Post Your Photos! 13 08-08-2007 04:43 PM
All times are GMT -7. The time now is 04:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
