09-23-2006, 11:19 AM   #1
Old Flash Unit with istDS
I have a Vivitar 283 flash unit (about 10 years old) that worked fine with my K1000 and ZX5n. Can I use this with my DS? It will fit the hotshoe but it doesn't have the same connections - not a TTL flash.
Thanks.
jrc
09-23-2006, 01:41 PM   #2
Ole
Ole's Avatar
Yes, use it as you would on the K1000:
Camera in manual, set the shutterspeed to or below the fash sync speed, set the aperture as per what the flash requires (depends on the ISO set on the camera).
Some flashes has a table or display which shows or calculates the proper aperture.
09-23-2006, 03:27 PM   #3
foxglove's Avatar
You might want to check the flash trigger voltage before you try out the flash - this is well explained by JensR's who posts over at dpreview. His site: http://www.jensroesner.de/ Your flash is probably fine, but why risk an expensive camera when it's so easy to check trigger voltage?
Julie
09-23-2006, 07:58 PM   #4
My 283 had about 500volts on the hot shoe connection. I only use it with a Wein safe sync.
Cheers
09-24-2006, 05:09 AM   #5
I'll get the mult-meter out today and check the flash. Thanks to all who responded.
jrc
camera, dslr, flash, flash unit, photography, unit
flash unit? smalle2007 Troubleshooting and Beginner Help 6 05-06-2011 01:37 PM
flash unit Rusky40 Flashes, Lighting, and Studio 15 01-12-2011 07:01 AM
Alien Bee Flash Unit or Ring Flash Hey Elwood Photographic Technique 2 06-24-2010 07:37 AM
AF160 Flash Unit gkamieneski Pentax DSLR Discussion 14 06-02-2010 08:02 AM
Pentax AF-16 flash unit miss_alexx Troubleshooting and Beginner Help 5 05-09-2010 07:54 AM
All times are GMT -7. The time now is 12:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
