Originally posted by carrrlangas any lens ever produced by pentax
Actually, any lens made for 35mm cameras will work. Screw mount lenses, either M42 (Spotmatic, etc.) or M37 (Asahiflex) require an inexpensive adapter.
Lenses for the Pentax medium format cameras, such as the 645, 67 or 6x7 require a rather expensive adapter, but can be made to work.
Auto 110 lenses can not easily be adapted, because the registration distance (lens mount to sensor/film plane) is much shorter on the 110 cameras.
Most third party lenses in Pentax mount work as well. There are two major exceptions: the dreaded Ricoh pin and some old Vivitar lenses.
Ricoh used a variant of the Pentax k-mount. In some of their models, there is an extra pin for lens automation, that is not present on genuine Pentax lenses. Unfortunately, this pin can become jammed in the auto-focus screw drive on a Pentax dslr. Not all Ricoh lenses have it, but be cautious when trying to mount a lens marked K/R or PK/R. The pin is easily disabled or removed and it serves no function on a dslr.
Some Vivitar lenses have a shield that protects the lens stop-down lever that is too long. When you try to mount one of these lenses, the shield hits the power contacts for the in-lens focusing motor and prevents the lens from fully seating on the camera. Again, this shield is easy to modify or remove, so that it does not interfer.
