07-18-2013, 02:37 PM   #16
QuoteOriginally posted by nomadkng Quote
I use higher end Hoya and Kenko
I think if you need to use UV filters to protect your lens, one should certainly go ahead. Some environments are hostile and dirty. But I'd only ever use a quality one like the Hoya's tested by lenstip.
Even then, I probably wouldn't use one at night, due to the risk of strange things happening on your images, like internal reflections, that I've seen even with Hoya filters. Pic related:
07-18-2013, 04:55 PM   #17
mikeSF's Avatar
there is a valid reason to use clear protection filters and there is a reason not to. Do not let anybody try to tell you different.
OK, that said, when I am shooting into the sun or for night landscapes, I take off ALL filters to prevent ghosting or excessive flaring.
I sometimes use a clear filter for macros...once was moving in close to a thorny rosebush and the thorn actually marked up my front element, dang! Also, found that dogs, horses, sheep, goats like to lick the front element as if it is water or ice or something. ask me how I know this. I so wish I had used a filter that day! Kid's b-day parties where the spontaneous water ballon, projectile vomit, silly string, could really tick you off without the extra protection.
I also shoot seascapes and pretty much leave off the filters, but I get salt spray and sand on my lenses all the time and have to wipe them fairly often on an outing. It is easier to clean a clear filter than those front elements.
camera, dslr, filter, lens, photography, uv, uv filters
Is the DA 18-135 really that bad? Rich7333 Pentax SLR Lens Discussion 22 09-17-2012 10:18 AM
Is the SDM failure rate really that bad coreyhkh Pentax SLR Lens Discussion 108 07-21-2012 07:33 PM
UV filters, do I really need one? TopherTheME Troubleshooting and Beginner Help 22 10-23-2011 10:08 PM
Are the sensor stains really that bad?? bobby_navy Pentax K-5 & K-5 II 6 12-29-2010 04:19 PM
To use UV filters or Not to use UV filters?HELP NEEDED Softsoap Pentax SLR Lens Discussion 6 02-20-2010 04:50 PM
All times are GMT -7. The time now is 12:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
