03-20-2008, 10:52 AM   #1
JCorwin's Avatar
K10 button.....loose?
I've had my k10 for a few months now, and I'm just noticing that the OK button and the 4-way controller button (that surrounds the OK button) on the back of the camera seems a bit loose. It functions properly, there just seems to be an awful lot of "play." How is yours? There's a good chance mine has been this way since I got it, and it's supposed to be like this, but I'm just noticing it now
jeff
03-20-2008, 12:09 PM   #2
ukbluetooth's Avatar
Mine is quite stiff ....
03-20-2008, 12:16 PM   #3
Sorry 0 that was a little facetious and jeuvanile - yes you are correct - there is a lot of play. It is perfectly OK.
03-20-2008, 03:30 PM   #4
Lloydy's Avatar
if you rub a finger over mine gently it moves around a bit as well
which I suppose makes it a bit loose.
03-20-2008, 11:24 PM   #5
JCorwin's Avatar
QuoteOriginally posted by ukbluetooth Quote
QuoteOriginally posted by Lloydy Quote
thanks, now I know mine's ok!
03-21-2008, 03:50 AM   #6
simons-photography's Avatar
mine moves around freely too I wouldn't worry bear in mind that it is sitting on a rubber pad and as the K10D has water seals it may be larger than most so adds a bit of play
05-07-2009, 08:42 AM   #7
bazzie's Avatar
Hi- I've just taken delivery of a GX10 and guess what? I have the same 'problem'. So I called Samsung, and they say it's normal (but then they would, wouldn't they ? )
05-07-2009, 09:39 AM   #8
OregonJim's Avatar
QuoteOriginally posted by simons-photography Quote
bear in mind that it is sitting on a rubber pad ... it may be larger than most
C'mon guys, you'll offend the ladies...
05-07-2009, 09:49 AM   #9
bazzie's Avatar
QuoteOriginally posted by OregonJim Quote
I doubt it from my experience
Any ladies offended?
05-08-2009, 12:33 AM   #10
res3567's Avatar
LOL!!!!!!!!
05-08-2009, 11:29 AM   #11
Jeff, I just took a K10D out of the box this morning and I notice the same thing you are talking about. I would say it's normal.
CW
button, camera, dslr, k10, photography
31mm - How loose is too loose? mmphilip Pentax SLR Lens Discussion 5 07-31-2010 02:34 PM
K-7 has something loose Plumas Pentax DSLR Discussion 24 02-25-2010 05:20 AM
K-m something loose? BrettWalker79 Pentax DSLR Discussion 15 11-07-2009 09:55 PM
K20D: Loose/wobbly four-way controller button... Jatcat Pentax DSLR Discussion 5 10-18-2009 04:02 AM
Something loose in new K7? Spock Pentax DSLR Discussion 5 08-17-2009 06:24 PM
All times are GMT -7. The time now is 12:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
