Here is a rough translation of a post in a German forum. Seems the OP had a lot of luck solving the "exposure issue" using a DS focusing screen in a K10. (or maybe just bad luck using a K10 screen in a DS???) Anyways, I tried to clean up the quote a bit. Test images look promising. The issue is how could a focusing screen diffuse the light enough to confuse the meter?
Hello Blende8, I have a Workaround using the original focusing screen from a istDs. You tested Tekade Schnittbildscheiben and LX screens, thus different screens and got other results. Through it you can confirm nor disprove then however neither my Workaround. It may be that my K10D is different than all different, but with me it works. I had straight on it no desire, but here an exposure series, in each case on the left of in the m-mode with the K10D screen in my istDs (I do not have desire to build now constantly there my Sucher am still dust free) and right with the istDs focusing screen in the K10D: F1,7: Image F2,8: Image F4,0: Image F5,6: Image F8: Image F11: Image F16: Image With F22 fell out of metering range, therefore no example. * istDs behaves with the K10D-Scheibe accurately as, as before the K10D with this disk.
The K10D works now just as accurately with * the istDS screen, as I was used to it of * istDs. This is with all means objectives with blendenring, that in such a way must it now however believe or also not - still more test patterns I make not Smile As said, perhaps I have only the impudent luck that only with my K10D goes in such a way. Around to judge would have to test others in addition, times * the istDs disk and not TeKaDe, LX, MX or other other disks in the K10D. Best greetings Rainer
DigitalFotoNetz.de :: Thema anzeigen - Workaround für K10D Probleme mit M-Objektiven
Anyone care to try the focus screen swap w/ a K10 and DS??????
