03-21-2008, 12:09 AM   #1
Sensor cleaning method - no tools - 100% effective and safe - 30 seconds.
Did a sky shot today and crap, there's dust on the sensor. Tons of it. Well about 8 specs.
So I took Ken Rockwells advice (I know, I know!!)... and flipped the mirror and used a vacuum cleaner, level with the lens mount. For 30 seconds.
Result? Perfect. 0 dust particles. Beats sending it in for a service. And as long as you're careful (ie: clean the vacuum nozzle first) and don't shove it into the body, what's there to lose?
Just an FYI and of course, YMMV.
03-21-2008, 12:23 AM   #2
Interesting ... but not sure if I'd want to put a Dyson close to it ... hee hee.
I'd be worried if something that may be slightly lose ... or not that secure internally ... gets sucked out of the camera body by accident.
It does sound interesting though.
03-21-2008, 12:44 AM   #3
Big Dave's Avatar
YMMV,
It sounds good, but I think that I would put a filter, such as a face mask between the vacuum and the body. You still should have enough suction, without the risk of back streaming particles.
Dave
03-21-2008, 01:42 AM   #4
ftpaddict's Avatar
How powerful is your vacuum cleaner?
Is a Hoover car sweeper enough?
03-21-2008, 02:06 AM   #5
that sounds interesting I just got my K10D and am dreading the day dust comes to town on me
03-21-2008, 04:37 AM   #6
Matjazz's Avatar
I doubt this method is more effective than a hand blower.
03-21-2008, 04:55 AM   #7
barbosas's Avatar
QuoteOriginally posted by Matjazz Quote
I also have my doubts...
Except for a couple of specs that didn't came out that simple, the rocket blower always worked for me.
But nice idea though, i might give it a try someday.
03-21-2008, 05:22 AM   #8
It is interesting idea but I would be worried about all the dust particles flying out of the vacuum's exhaust thingy.
On the other hand Rocket Blower rocks. First time I used it it removed all dust specs that I had. Just few blows did it.
03-21-2008, 05:31 AM   #9
Dangerous!
I don't think this method is "safe". IMO, it is very dangerous.
Putting aside that the vacuum cleaner by itself is a very dirty thing which full of dust (even you cleaned the nozzle), the huge suction force may damage the delicate camera parts like the very thin shutter curtain.
So, just don't try it. If you success this time, you're just *lucky*! Just use an air-blower in the first place to do the job! If the dust particles are sticky, use wet clean (Sensor Swap etc.) or use the Pentax official method to clean (a delicate cleaning tip/head and a cleaning paper for the head).
Lastly, I can't imagine when an air-blower cannot do the job, a vacuum cleaner can! (in case of sticky dust particles)
QuoteOriginally posted by 123K10D Quote
03-21-2008, 06:03 AM   #10
Tom M's Avatar
This is basically my technique- I use a cotton swab to knock loose the particles then blow across the mount opening which creates a vacuum sucking the dust particles out. My tools are usually only a Q-tip and my lungs.
It works very well and has not damaged the glass covering the sensor in any way.
03-21-2008, 06:32 AM   #11
Lowell Goudge's Avatar
QuoteOriginally posted by RiceHigh Quote
RH
I can't agree more.
If the force of directed air from a blower won't remove the dust, then the indirect air flowing over the sensor from a vacuum won't do it either.
Additionally, where does the air come from that the vacuum sucks in?
on a K10D the camera is sealed, therefore the vacuum is either putting a very high pressure on the seals, trying to make them fail, or the air is coming in around the lens mount, at the vacuum nozzle, and not going past the sensor at all.
to me, if the sensor was 100% cleaned by this method, it is pure luck.
The only possible use I can see for a vacuum, is a very low speed (air speed that is) one, with a hepa filter, about 2-3 inches away from the camera to capture any dust that you dislodge with the blower, but this should only be done in a clean room, because the air movement in the room, caused by the vacuum will be moving past the lens opening all the time, potentially dropping more dust into the lens.
03-21-2008, 07:55 AM   #12
Crazy Ken Rockwell !
RH
I can't agree more.
The OT poster said it is taught by Ken Rockwell, is it true? It seems like he has just too many DSLRs and lenses for him to abuse and his cleaning methods are often crazy! e.g., use the shirt sleeves to clean lens optics etc. - well, at least a tissue or even toilet paper is better, I bet!
03-21-2008, 08:02 AM   #13
deejjjaaaa's Avatar
: it is taught by Ken Rockwell
Ken Rockwell is like Chuck Norris, he just use a vacuum cleaner instead of a kick to beat the dust out of.... sensor.
03-21-2008, 10:02 AM   #14
superfuzzy's Avatar
Perhaps another lens cleaning device - a small tabletop vacuum with a k mount. Attach the camera with the back facing up toward the ceiling, raise the mirror and turn on the vacuum unit. That is if it works...
03-21-2008, 10:07 AM   #15
ryan s's Avatar
We had a discussion relating Rockwell to Norris...some good stuff...and yeah, the only thing of his I use is Tshirt for cleaning lenses. But that was also recommended to me to clean my glasses so...
camera, dslr, dust, photography, sensor, vacuum
sensor cleaning schmik Pentax DSLR Discussion 10 05-29-2008 09:33 PM
Sensor cleaning: Pec-Pads or Sensor Swabs gadgetnu Pentax Camera and Field Accessories 29 09-24-2007 10:52 AM
New Sony APS-C size CMOS Image Sensor with 12.47 Effective Resolution for use in DSLR Matjazz Pentax DSLR Discussion 4 08-20-2007 02:42 PM
Sensor cleaning > Sensor Swab > void warranty? Twinky Pentax DSLR Discussion 2 07-28-2007 01:10 AM
Sensor Cleaning Tools Old Timer 56 Pentax DSLR Discussion 12 06-30-2007 08:09 AM
All times are GMT -7. The time now is 02:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
