08-10-2013, 09:33 PM   #1
Battery in grip
I have a BOWERS battery grip for the K-7 for about a year now. All the functions of the grip work fine, but recently I was running out of power faster than I thought I should be, so I checked the set up and saw that the grip battery is crossed. (see attached pic)
Attachment 183606
I put in a new fully charged (PENTAX) battery, same thing. I swap the cartridge out to the one with charged AA eneloops, same thing.
Yep, cleaned the tips of the sprung contacts and the camera docking points, still the same.
Took the battery out of the camera and fitted the grip only with the battery, nothing - won't fire up (camera setting is on auto select)
As I say, all the functions of the grip work fine it just doesn't seem to be receiving any power from it..
Anyone else had this happen?
08-10-2013, 09:56 PM   #2
manacho2005's Avatar
I have the Meike version for my K5, the only batteries that the camera sees with it are alkaline AAs :\
08-11-2013, 02:58 AM   #3
Make sure the grip/body contacts are clean and not damaged and functioning properly, by which I mean that the contacts in the grip are sprung loaded and should all be standing at the same height. Check one (or more) isn't depressed into the grip.
08-11-2013, 03:17 AM   #4
Hi John,
You might have missed this in post #1. Contacts already checked..
Just to repeat, all the functions of the grip work fine it just doesn't seem to be receiving any power from it..
08-11-2013, 05:41 AM   #5
Kobayashi.K's Avatar
Are you only seeing Auto Select?
Menu Tool | 3 | Select Battery |
Use the four way controller Up or Down to select Auto, the internal battery, or the battery in the grip. In the latter case you can also select the battery type.
See page 270/271 of your manual (k-7.pdf).
08-11-2013, 06:10 AM   #6
QuoteOriginally posted by JohnX Quote
Of course, it's wrong when one or more contacts are depressed into the grip. However, not all the contact pins on the D-BG4 are on the same height by design. There are 3 pins that are a bit thicker (I guess for power) that are higher. One thin pin is also lower than the rest. This is probably a security measure in case the grip is mounted when the camera is on (not recommended), to ensure power and signal lines are connected in a correct order.
08-11-2013, 06:14 AM   #7
QuoteOriginally posted by Kobayashi.K Quote
No...
08-11-2013, 07:23 AM   #8
Hadn't noticed that before.
09-12-2013, 09:20 PM   #9
Anyone know which pins are for the power connection?
battery, camera, dslr, functions, grip, photography, power
Battery grip battery not showing up Kees-Jan Troubleshooting and Beginner Help 12 05-23-2015 02:33 PM
K200d Battery Door, No Power stand alone, But works with Battery grip pento57mm Troubleshooting and Beginner Help 10 08-18-2013 11:24 AM
Precautions in buying k7+Neewer battery grip NicZh Troubleshooting and Beginner Help 20 02-17-2011 07:31 AM
Availability of battery grip D-BG4 in Europe Tintin Pentax K-5 11 02-14-2011 11:56 PM
Fast Battery Drain in BG2 Grip rickn Pentax Camera and Field Accessories 4 10-29-2009 05:15 PM
All times are GMT -7. The time now is 08:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
