Originally posted by wildman Yes.
No.
I see no necessary contradiction whatsoever. I am not proposing that the present configuration of TAv mode should be abandoned but, rather, that there should also be an additional optional user setting for those that want it.
Simply put - I tell the gear how I want it to work not the other way around.
And I bet it wouldn't take more than a few additional lines of code in the next BIOs update.
Thanks for your thoughts.
There is an additional setting, in fact 2 - they are called Tv and Av! If TAv isn't working, one of those can do the same thing. Also agree with the other points here that checking exposure and aperture/shutter speeds should be part of the dance you're talking about, not apart from it.
