08-18-2013, 09:44 PM   #1
pentax k-x best memory card recommendations?
hi guys just wondering what would be the best memory card i should get with my pentax k-x...
ryt now i have a 16 gb sandisk 30 mb/s
i was thinkin of getting a sandisk extreme pro 95mb/s 64 gb card...
but would that even recommended in a k-x? or a 40mb/s would good enough for burst shots?
and would burst shots doable with k-x?
can k-x do burst shots?
thanks everyone
hope to see some replies
08-18-2013, 10:55 PM   #2
Your 30Mb/s card probably has a write speed of 10Mb/s, so I'd say go for a 45mb/s. The actual maximum write speed is around 30Mb/s, I believe, and definitely not higher than 45 so the pro card won't do you any good.
The 16gb 45 card has a pretty nice discount at the moment:
SanDisk 16GB SDHC Extreme Class 10 UHS-1 MemorySDSDRX3-016G-A21
The K-x has a burst mode that can shoot 17 jpegs at 4.7 fps
08-19-2013, 12:23 AM   #3
First, be sure to have the newest firmware on your K-x, because there were some issues in the past with the support of large SDHC cards.
A (professional) member of a dutch Pentax forum dit a test in practice with the fastest memory cards, and found out that the max. write speed of a K-5 was about 20 mb/s. with RAW bursts. Someone else on a forum mentioned a max. measured write speed of 18 mb/s.
Cards with a faster write speed are not usefull on a K-5. I suppose the K-x doesn't write faster than a K-5.
08-19-2013, 05:11 AM   #4
Have a go with an Extreme Pro card. It might make a difference in camera.
Even if it doesn't speed up your burst rate, it will certainly speed up transferring images from your card into your card reader and onto your PC, which in itself can be handy.
FWIW, I've used Sandisk Ultra's and an Extreme (but not Extreme Pro) with the K-x with good performance. Ditto with a Lexar Platinum II Class 6 SDHC card.
burst, camera, card, dslr, gb, k-x, memory, memory card, pentax k-x, photography, sandisk, shots
K-x Memory Card Errors pearsonbe Pentax DSLR Discussion 10 07-30-2012 10:39 AM
Best memory Card for 645D SDHC vs. SDXC? Ryan Tischer Pentax Medium Format 10 02-21-2012 02:30 AM
Best memory card for the k-r? dmcd11 Pentax K-r 17 08-18-2011 01:01 PM
[k-x]Video + battery + memory card quetions jupzchris Video and Pentax HDSLRs 2 04-21-2010 09:58 PM
Best memory card for Pentax DSLR lesmore49 Pentax Camera and Field Accessories 19 02-16-2009 11:55 AM
All times are GMT -7. The time now is 09:41 AM. | See also: NikonForums.com, part of our network of photo forums!
