09-04-2013, 10:45 AM   #1
bunkachunk's Avatar
new lens = dark pictures
Hi, I have the k-30 "kit lens dal 18-55" and bought the smc pentax da 50mm f1.8 lens. when the camera is set to auto all the pictures come out dark. with the kit lens, pictures are fine. histogram shows the peak on the far left w/ the 50mm lens on. I am coming from the land of point and shoot, but I'm learning fast. have had the camera for about two months now. pictures were taken on bright sunny day. I am using m mode as much as I can, like I said, I'm still learning to use all the cameras functions. what am I doing wrong or is this the nature on this lens? I have attached a few sample pictures. Thanks.....
PENTAX K-30  Photo
PENTAX K-30  Photo
PENTAX K-30  Photo
PENTAX K-30  Photo
PENTAX K-30  Photo
09-04-2013, 11:05 AM   #2
The exif data shows that you've dialed in a negative exposure compensation for all these shots. Reset it back to 0 and you should be good to go.
09-04-2013, 05:00 PM   #3
Kozlok's Avatar
I would also go into the menu under "memory" and clear off the box for exposure compensation. That way, even if you set EC on purpose, when you cycle the camera off and on, it will automatically reset to zero. While you're in there, uncheck any other boxes of stuff you think you might forget to reset.
09-04-2013, 05:36 PM   #4
twitch's Avatar
QuoteOriginally posted by Kozlok Quote
Good tip, I've been burnt by the camera remembering previous EV compensation many times.
09-05-2013, 10:49 AM   #5
bunkachunk's Avatar
ADAM, thank you for the reply, reset to zero and all is well, now the only thing left to do is go out and see how much better this nifty fifty is over the kit lens. Thanks' again, bunkachunk........
09-05-2013, 10:53 AM   #6
bunkachunk's Avatar
KOZLOK, Thank you for your reply, went into memory and I did have everything checked, unchecked all, now no problems, pitchers are coming out great. Thank you very much. bunkachunk.......
50mm, camera, dslr, lens, photography, pictures
Pictures too dark in Windows Photo Viewer thechumpen Digital Processing, Software, and Printing 9 06-17-2014 05:19 AM
K7 Pictures always too dark addicted2climbing Pentax DSLR Discussion 12 09-07-2012 04:44 AM
dark pictures on program setting kevinsterner Troubleshooting and Beginner Help 8 12-22-2011 02:20 PM
dark pictures with my new K-20 CAFEDE Troubleshooting and Beginner Help 9 09-16-2011 04:54 PM
K10D Lens Help / Dark pictures Amydaveg Pentax DSLR Discussion 2 04-05-2009 08:04 PM
All times are GMT -7. The time now is 07:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
