09-05-2013, 08:12 AM   #1
is there a cheap battery eliminator for the kx or DIY??
After last night's astro session, there's one thing I need to do.... get this camera off of batteries! Since there's no jack for external power, is there a cheap eliminator that would replace the batteries or something DIY? Thanks.
09-05-2013, 09:27 AM   #2
Kobayashi.K's Avatar
The K-x has no jack for external power, but it has an AC Adapter kit (K-AC84) that has two parts. One part is a DC coupler that goes inside the battery compartment (replacing the batteries), and the other part is the actual AC power supply. They are connected via a cable.
The K-x PDF manual has a complete description how to use it:
Operation Manuals Download : Support & Service | RICOH IMAGING
09-05-2013, 03:01 PM   #3
JimJohnson's Avatar
Go to the sub-Forum on Pentax Articles and scroll through the Do It Yourself section. There are at least a couple options. I paid very little to make one for the K-r.
09-06-2013, 11:49 AM   #4
Basically you need some AAA to AA adapters, some wire, a soldering iron, and a regulated 6 volt wall wart.
http://www.welcome.zaq.jp/moonlight/k-m.html
batteries, camera, dslr, eliminator, photography
Is there a small, cheap bounce flash for the Q? GibbyTheMole Pentax Q 17 05-20-2013 05:32 PM
Is there a good reason to go for a 45 and or 55? slackercruster Pentax Medium Format 9 06-18-2012 05:12 AM
Battery eliminator suggestion for K100DS? ismaelg Pentax DSLR Discussion 2 09-23-2011 05:04 AM
Cheap or diy bracket for softbox? pete_pf Flashes, Lighting, and Studio 11 07-27-2011 02:47 PM
Is there a cheap light meter for usage with manual lenses? justtakingpics Pentax SLR Lens Discussion 19 04-06-2011 09:29 PM
All times are GMT -7. The time now is 04:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
