09-09-2013, 03:57 AM   #1
Can I use these lenses with a K-5 camera?
Hi all,
I hope you can help with this ... I have some Pentax SMC lenses that I would like to use with a K-5 camera, however, I'm not quite sure if it is possible nor if there will be some limitations in the use (besides manual focus).
The lenses I have are these:
Pentax M zoom 80-200 mm: SMC Pentax-M 80-200mm F4.5 Reviews - M Zoom Lenses - Pentax Lens Reviews & Lens Database
SMC Pentax 24 mm 1:2.8: SMC Pentax 24mm F2.8 Reviews - K Prime Lenses - Pentax Lens Reviews & Lens Database
SMC/S-M-C/Super-/Auto-/Takumar 55mm F1.8 w. M42 screwmount: SMC/S-M-C/Super-/Auto-/Takumar 55mm F1.8 Reviews - M42 Screwmount Normal Primes - Pentax Lens Reviews & Lens Database
Might one of you know if I can use (some of) these lenses with a K-5 and also if there will be some limitations in practical use?
Thanks for reading & maybe replying
Jesper
09-09-2013, 04:11 AM   #2
drypenn's Avatar
All of them will be usable.
The first two can be mounted directly, while your M42 Tak will need an adapter M42 to K-mount adapter.
Limitations? All of them requires manual focusing and exposure metering. Try to learn both and pretty soon, only your imagination will limit you
09-09-2013, 04:47 AM   #4
Hi drypenn,
& thanks for your quick & helpful reply! I wonder though what this means in practice:
QuoteOriginally posted by drypenn Quote
exposure metering
Does it mean that I have to manually adjust a scale of some kind to make the shutter speed fit with the light available or can this be done automatically? What I would be fine with doing manually is adjusting the focus and aperture values but I would prefer the shutter speed to be automatic. Do you know if this is possible?
Greetings,
Jesper
09-09-2013, 04:52 AM   #5
Ooups - looks like "Not a Number" answered my question while I was writing my last post. So it looks as if it will be possible to have the camera do the shutter speed calculation - great!
Thank you both for replying ;-)
Jesper
09-09-2013, 04:53 AM   #6
mythguy9's Avatar
QuoteOriginally posted by evalon Quote
You will have to use the green button to stop down meter. For all K and M lenses you should shoot in Manual mode, press the green button so the camera will give you a shutter speed (pairing with your manually selected f-stop), then release shutter.
Your M42 lens can be used in Av mode when you switch the aperture to manual.
Check the links given by Not a Number above.
camera, database, dslr, f1.8, k-5, lens, lenses, m42, pentax, photography, reviews, screwmount, smc
Can I use an old SMC PENTAX- M 1:1.7 50mm lense on a brand new K-01 or a K-5? jjuanmartin Troubleshooting and Beginner Help 5 12-23-2012 04:38 AM
Can I safely use Vivitar 285HV with K-5 using Wein Safe Sync or Pentax PX cord? Dnabors Troubleshooting and Beginner Help 7 06-13-2012 12:05 PM
Can K-5 camera use Old K1000 Lenses!!! hrgagan Pentax K-5 5 04-06-2012 02:23 PM
Can I use nikon lenses on my K-5 aussiemick Pentax K-5 2 04-28-2011 08:06 AM
Can I use these lenses fishnuts Troubleshooting and Beginner Help 4 04-27-2011 02:17 AM
All times are GMT -7. The time now is 06:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
