Originally posted by shutterpuppy I'm content with shooting at ISO 800 if the quality is better than my old Fuji s8000fd which was lousy at that setting, how is the auto W/B setting with mixed lighting? Thanks everyone for your advice.
Barry
If you shoot RAW, you can correct the lighting balances in post processing. At something like a car show (or any indoor display type function), I would think this would be the only way to go.
If you attempt to use the in camera white balance fine tuner, you would be spending all your time tuning the white balance. The mixed lighting means that each car, and probably each side of each car, will have a different lighting mix, which would require you to set the balance for each shot. You could conceivably have a mix of tungsten, halogen, fluorescent (and different fluorescents), mercury arc and the Lord only knows what all else, not excepting coloured gels!
In post processing, you can look at an image and make the white to be white. A lot more work, yes, but the only way to get acceptable colours.
