Originally posted by Outlaw Interesting - who/which brand would you recommend or is that question stretching the bounds of professional ettiqutte?
Even a glimmer in the right direction would help out. Thanks.
Memories, like anything, have different "grade" levels. So even "dice" (raw, unpackaged chips) from the same wafer will perform differently under the same set of tests, mainly because of physics. So a die on one corner of the wafer may be faster than a die on another corner on the same wafer, for example, and hence will be placed in a higher-grade bin.
"Brands" buy from different memory manufacturers - Qimonda, Samsung, Hinix, Mocron to name a few - and in the memory industry, that's usually the house with the cheapest price. When they do, they also buy the different grade levels to service a certain market. For example, server-grade memory is understandingly more expensive than commodity-grade (home PC). Dell is one of the PC vendors that buys the higher-grade memory products, and my 1996 Dell PC shows it (now retired).
So the old adage "You get what you pay for" may be true when considering flash cards for the camera - the more expensive ones are probably better the the cheaper ones. So a a pricier 4GB BrandA may indeed be better that a "much" less pricey 4GB BrandB, However, I can't really tell which would be better between 2 comparably-priced brands, with comparable specs.
Hence I asked for advice based on experience, not just specs.
