03-28-2008, 03:05 PM   #1
Setting the shutter speed AND aperture on the K10D
Okay, I can set the aperture. I can set the shutter speed.
Problem is, whenever I set one, the camera takes it upon itself to set the other. If I want depth of field, the camera always thinks I need a long exposure. Even when I don't.
How do I override this?
Also, which flash units are compatible with the K10D?
03-28-2008, 03:07 PM   #2
QuoteOriginally posted by Photogoof Quote
You are in P mode. You want to be in M mode.
03-28-2008, 03:12 PM   #3
Or shoot in TAv mode - set Av and Tv and the camera will select ISO for you.
03-28-2008, 03:19 PM   #4
travis_cooper's Avatar
Its not like you can just set your aperture and shutter speed to whatever you want. You can only go so far away from what your camera wants to do before you'll get a picture that is exposed to poorly that you won't be able to use it.
ETA: If you just want to change it a little bit I'm a huge fan of using EV compensation.
aperture, camera, dslr, k10d, photography, shutter
K-x bottom shutter speed setting? olenl Troubleshooting and Beginner Help 3 09-22-2010 11:17 PM
K-X setting for shutter speed fekish Troubleshooting and Beginner Help 6 09-07-2010 03:18 AM
Setting shutter speed on K200 frankknight Troubleshooting and Beginner Help 5 10-27-2009 08:56 AM
K20D & setting shutter speed UpNorth Pentax DSLR Discussion 8 01-09-2009 10:11 PM
Please help a K10D n00b with aperture and shutter speed PaddyB Photographic Technique 11 09-25-2008 06:46 AM
All times are GMT -7. The time now is 12:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
