I have a K-x with under 5k shots on it that has recently begun to produce occasional all-black images, usually the first one or two shots of a session. Today the AF motor refused to get a lock even in good lighting. Manual focus worked fine. After turning it off and back on, it started focusing okay, but seemed a bit slow. (The last bit might be my imagination.)
Apparently, my K-x has become aware that I've been eyeballing a K-3 now that I am getting more serious about photography and may be staging a strike.
So... I am guessing that any shutter repair (if indeed that's what it is) will run ~$200, and I doubt I could get that for the body alone at this point, even repaired. I had planned to ask for a new lens at Xmas, then buy the K-3 early next year, and keep my K-x as a backup.
1) Am I correct in assuming it's probably not worth sending away for repair?
2) Is there a DIY fix I could attempt to clean the shutter?
3) Given that this camera has light usage and has never been dropped or been in harsh environments like dusty or salty ones, am I correct in being rather annoyed at such a short lifespan?
