10-27-2013, 11:06 AM   #1
vagrant10's Avatar
What bodies to bring to Angkor Wat?
This is a little different twist on an oft asked question - what to bring on my vacation? But this time I'm wondering what bodies to bring...
So, I'm bringing two bodies, k5iis for sure is coming. But the second could be a k7 converted to IR or a k5 w/ a second lens. I suppose I could bring an IR filter that will fit on some of the lenses I have, but that will really slow things down - tripod set up and all that. I suppose I have to ask how many IR shots do I plan on taking? Thing is, I've been there before, so I already have a lot of shots - but this will by my wife's first trip there and I don't want my photography to be too much of a drag for her. And I think IR will add a lot to many of the temple over-ran by the jungle pics...
I'm just agonizing over this decision - what do you think?
10-27-2013, 01:09 PM   #2
Which lenses is much more important question. I would easily take the IIs and the K-5. When and how you get out to Angkor Wat matters... the light is what makes the difference there. You could probably save yourself some trouble and take the IIs and a more lens options.
10-27-2013, 02:46 PM   #3
vagrant10's Avatar
The lenses I have figured out and discovered last time the truth of what you're saying regarding the light.
I've decided to bring the following lenses (the # beside the lens is the weight in grams):
12-24 431
50-200wr 286
16-50wr 565
55 1.4 375
fa77 - da15 269 212
k to q? tc’s raynox
10-27-2013, 11:46 PM   #4
i_trax's Avatar
I went there last DEC,
I took just K-30 with Sigma 17-70 Macro 2.8-4.5 + DA 18-250
with lot of AA lithium batteries, they last forever
do Sun rise ( ~ 5am) at Banteay Srei , the pinkish stone is magnificent
some of my photos:
Flickr Search: banteay srei
11-07-2013, 10:58 AM   #5
vagrant10's Avatar
decided to bring the k5iis, k30, k7 ir, and q. I'll probably have the 15 mounted on the k7ir and keep that for special situations. I'll have the 12-24 on the k30 and the 16-50 on the iis. If I don't need superwide, I'll swap out to either the 77 or 55.
looks like this gear weighs around 25 lbs including tripod so not too bad. Wish I could bring some better long glass, but weight in the heat will wear me down too fast.
bought a 10 stop filter - hopefully this will let me thin out some of the crowds of people in the photos...
can't wait to try some of this stuff out!
11-07-2013, 11:02 AM   #6
vagrant10's Avatar
QuoteOriginally posted by i_trax Quote
some of my photos:
awesome, thanks for the tip. so any other small less known temples that you found worthwhile?
11-07-2013, 11:54 AM   #7
I would left either 55 or 77 home. Also one body would be enough for me.
11-07-2013, 01:17 PM   #8
vagrant10's Avatar
QuoteOriginally posted by Joojoo2010 Quote
The 55 is primarily for rain or wind at the beach - the 77 is for when I need a little more reach than the 16-50 - I also like it because it's look is a bit more attractive to me, particularly its bokeh. I found last time changing lenses was just too time consuming so 2 bodies was a minimum. and wanting to shoot IR meant that body #3 was important. I'm sure there will be plenty of times the IR cam is staying in the room, but there are some shots I'm very curious to try out.
11-07-2013, 01:29 PM   #9
Senior Moderator
Parallax's Avatar
QuoteOriginally posted by vagrant10 Quote
IR filters on digital that hasn't been converted to IR doesn't work all that well (though the K5 IR mode isn't too bad).
You put a filter in front of the lens that lets, theoretically, only IR light pass through, but there's a filter over the sensor that, theoretically, blocks all IR light. Neither filter is 100% efficient so there is some effect, but it's minimal. Since you've been there before and have many pictures already; if you want IR shots take the converted K7.
(Or take all three and make your wife carry one. )
bodies, camera, dslr, ir, lot, photography, shots
What lenses to bring on a trip to NY & DC? lenp Pentax SLR Lens Discussion 16 06-24-2013 05:45 AM
Travelling to Alaska - What equipment to bring... kaarde Travel, Events, and Groups 6 05-15-2012 08:20 AM
Travel, Cuba, flatsfishing...what to bring? morpho Pentax Camera and Field Accessories 2 05-06-2012 04:20 AM
What gear to bring to New Zealand dane.dawg Pentax K-5 11 11-12-2011 09:03 AM
Going to Siem Riep Cambodia - what to bring? ducdao Pentax SLR Lens Discussion 16 05-09-2011 12:37 AM
All times are GMT -7. The time now is 07:27 AM. | See also: NikonForums.com, part of our network of photo forums!
