03-31-2008, 12:42 PM   #1
joefru's Avatar
K10D auto ISO
A silly question, I know. Is there a way to easily reset the ISO to auto on the K10D? I usually use auto up to ISO640, but if I want a little boost, or if I want to force it a little higher, I can hold OK and spin the rear e-dial. (That was enabled with firmware 1.3?) I love that feature, but I'd also love to be able to return to auto just as easily.
I have it set to "forget" the WB and ISO settings, so I can turn it off and on to reset it, but is there an easier way?
03-31-2008, 01:21 PM   #2
I think if you hold down Ok and hit the green button, it'll reset your ISO to auto.
03-31-2008, 01:26 PM   #3
Moderator Emeritus
That's what I do.
04-01-2008, 08:18 AM   #4
joefru's Avatar
Awesome. Thanks! I knew there had to be an easy way.
04-01-2008, 11:32 AM   #5
moxfyre's Avatar
QuoteOriginally posted by joefru Quote
Yes indeed, you can hold down "okay" and hit the "magic green button." This drove me nuts till I figured it out
Also: in the Custom Settings menu, you can make it so that it uses the "spare dial" for ISO adjustment in Av/Tv mode. Really convenient!!! That way, you don't even need to hold OK to make ISO adjustments.
04-01-2008, 12:10 PM   #6
joefru's Avatar
QuoteOriginally posted by moxfyre Quote
Yes, I have mine set that way, but you still can't get back to auto without OK+Green, right?
04-01-2008, 12:20 PM   #7
moxfyre's Avatar
Hmmm... on mine, Green alone does it, in Av mode at least!
04-01-2008, 01:23 PM   #8
PentaxPoke's Avatar
Thank you! This bugged me too, but I never knew how to reset the auto iso without going back through the LCD.
04-01-2008, 07:51 PM   #9
Lowell Goudge's Avatar
If you want your "normal" settings and you want a boost setting occasionally, why don't you set USER mode to the Higher ISO and set the ISO for the other modes as you indicated you want.
User mode can have totally independant ISO and WB settings from all other modes
auto, camera, dslr, iso, k10d, love, photography, reset
Auto iso - k10d stevewig Pentax DSLR Discussion 10 03-25-2010 05:32 PM
K10D and AUTO ISO with manual lenses kevbirder Pentax DSLR Discussion 10 11-15-2008 10:03 PM
Another K10D auto-iso bug? twinda1 Pentax DSLR Discussion 0 03-12-2008 10:19 PM
K10D. Bug with Auto ISO in P mode? Edvinas Pentax DSLR Discussion 21 12-30-2006 05:47 PM
K10D Auto ISO now works with Exposure Compensation? RiceHigh Pentax DSLR Discussion 15 12-02-2006 06:27 PM
All times are GMT -7. The time now is 07:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
