11-05-2013, 09:50 PM   #1
Patched Rom for Downgrading 1.31 K10D
The method is pretty easy, simply change the rom's header file to 1.31 and the Camera will then be able to load the older firmware.
The so called "hacked 1.10 firmware" that will downgrade 1.30 to 1.10, is using the same idea.
So here is file you can use to downgrade 1.31 to 1.10. After applying this rom, apply the original 1.10 rom, so you can get the system version right.
Patched 1.10 ROM: http://file01.tnder.org/207002-Patched-1.10.zip
Original 1.10 ROM: http://file01.tnder.org/177002-Original-1.10.zip
Just put the ,bin file at the root of SD card. Power the camera off, then power on with menu pressed and hold. The patched 1.10 ROM will prompt to be 1.31, but it is actually 1.10.
Same idea should work on other models as well.
11-06-2013, 08:26 AM   #2
pacerr's Avatar
This note ought'a go to the articles section with some useful search tags.
[like K10, firmware, reversion, etc. ]
H2
11-06-2013, 11:22 AM   #3
QuoteOriginally posted by pacerr Quote
H2
Er.. Do you know how can I do that?
camera, downgrade, dslr, idea, method, photography, power, rom
Debug mode with K10D FW 1.31 smurfy27 Troubleshooting and Beginner Help 20 04-03-2024 12:48 AM
K10d : downgrade from 1.31 to 1.10 ? clover Pentax DSLR Discussion 14 03-17-2013 10:24 PM
Grit in the focus ring of my 31/1.8 Finn Pentax SLR Lens Discussion 2 01-10-2013 01:28 PM
Question Regarding K10D software version 1.31 Meter Problems crashmars Troubleshooting and Beginner Help 2 11-27-2011 03:10 PM
Shutter lag and firmware update? (K10D & 1.31) frattofoto Pentax DSLR Discussion 3 05-02-2010 01:46 PM
All times are GMT -7. The time now is 10:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
