04-02-2008, 08:50 AM   #1
Giveaway winner!
K20D dithering problem
Hi, i just tested my new k20d outdoors during the WE
i quite frequently get vertical lines every two pixels of the image like this:
what is the problem
firmware bug? sensor problem?
and what can i do?
thank you for your information
Philippe
04-02-2008, 09:14 AM   #2
QuoteOriginally posted by phler2 Quote
what is the problem
and what can i do?
Philippe
Try a different SD card.
Ray
04-02-2008, 11:22 AM   #3
benjikan's Avatar
That is definitely the card. Had the same problem with a slow card and reader.
Ben
04-02-2008, 12:07 PM   #4
Giveaway winner!
thanks for the answers,
i'm surprised thought, how come the card is in fault here
i have an extreme III HC 4GB which otherwise seems to work perfectly and is very fast
if you have any details on that i will be interested
thanks
04-02-2008, 01:48 PM   #5
benjikan's Avatar
thanks
What is the card reader you are using?
04-02-2008, 04:53 PM   #6
MJB DIGITAL's Avatar
bump
im interested in avoiding this problem
04-02-2008, 05:40 PM   #7
Giveaway winner!
card reader? you mean to read the card on my pc, it is the usb scandisk provided with the SD
thought i don't beleive this has anything to do with the stripes i get
however, i do not think it has to do directly with the card :
after some more observation, i figured that this problem only happens for the first shot i take after turning on the camera
i do a lot of panoramas with hugin (great tool) and it is always (when it happens) the first picture that is affected
i beleive either their is some initialiasing isues that happens occasionly
perhaps it may be due to the weather, it was below 0°C perhaps -10
i was suggested by a friend it might be due to the D-range function which i believe was on
also it is probably a processing error perhaps during the bayer matrix conversion, as it is clearly a vertical sinc with a 2 pixels period.
anyhow, it seems that to avoid the problem one may want to take a first shot to make sure it is fine
note that due to the sinC period, when sampling down the image to show on the LCD screen, you can see the stripse thought at a lower frequency (nyquist effect). so you now if the problem is happening.
some pentax engineer arround reading this might have an idea if there actually is a bug here??
thanks
04-07-2008, 02:35 AM   #8
falconeye's Avatar
Your K20D is broken. Return it or get it serviced.
12-14-2008, 08:53 PM   #9
jeffkrol's Avatar
I agree fully. Maybe a bad sensor or trace or power circuit. Whatever it is it really need the camera replaced........ not fixed.....
Apparently it occurres in the Nikon d200 as well.......
Maybe searching the Nikon sites will reveal the cause.
guess I'm a bit surprised in the fact it's in a 20d w/ a CMOS sensor. Leads me to believe it's a problem not related to the sensor but more to do w/ a bad board/ ADC/ power supply....whatever
Nikon D200 Reviewed. Noise Performance
Discussion Forums @ Nikonians - D200 and banding
http://www.scribd.com/doc/6715284/CCD-Noise-Sources
Looks like silkypics can remove it..
http://www.isl.co.jp/SILKYPIX/english/newsletter/051222/
02-21-2009, 10:34 AM   #10
Affe's Avatar
I´m having the same thing. Zig-zag shaped strips so ugly that I´m almost turning Nikon...
Benjikan´s talk about the card got me thinking... So I formatted my card after two years of use.
My first impression is that the strips are gone or wery reduced.
02-22-2009, 07:40 AM   #11
Giveaway winner!
QuoteOriginally posted by Affe Quote
if it is zig-zag lines and not the vertical banding issue i have
than it might be RF interference
this will happen if you are close to a gsm (cellular) base station, e.g often on building roofs
search for it on the Internet, you,ll find example pictures
02-22-2009, 07:49 AM   #12
Giveaway winner!
oh and nikon will not be better at that, nor canon.
but film cameras wont have the problem
02-22-2009, 09:15 AM   #13
Tuner571's Avatar
So phler2, was your K20D ever fixed? If it was, do you what was causing the problem?
02-22-2009, 10:05 AM   #14
Giveaway winner!
QuoteOriginally posted by Tuner571 Quote
Hi,
actually, i had started an other thread after i had received my k20 back from pentax without any changes to it.
that thread has been quite active on the subject, which seems to be quite common, i'm not saying very common, but enougth that there are a few person reporting the same issue
here it is:
https://www.pentaxforums.com/forums/pentax-dslr-discussion/43634-k20d-vertical-strips-7.html
on the bad news, i have had my camera changed, but the new (actually refurbished) one was faulty too... but i know many people shoot in cold conditions without any problems
i have moved to switzerland now, and pentax there seems much more responsive than in quebec. i have sent it back again. we'll see whats next.
02-22-2009, 11:05 AM   #15
mike.hiran's Avatar
Did you ever try replacing the SD card?
camera, dslr, k20d, photography
K20D AF problem benjikan Pentax DSLR Discussion 21 02-25-2024 10:51 AM
problem with new K20D geckogrin Pentax DSLR Discussion 12 11-07-2009 11:21 AM
K20D Problem photoTaz Pentax DSLR Discussion 2 06-21-2009 09:25 PM
Card read problem K20d. Have you had this problem? rsi1986 Pentax DSLR Discussion 8 12-27-2008 05:25 AM
K20D problem ariahspam Pentax DSLR Discussion 6 06-06-2008 12:10 PM
All times are GMT -7. The time now is 04:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
