Originally posted by Swift1 Here's one of my older (2008) K10D shots that I ran through ColorEfex Pro 4.
Pentax K10D
SMC Pentax-DA 18-55mm f/3.5-5.6 AL
See, now there's the master at work, I'm striving to get mine to look a bit more like this look that comes so easily to you, but that's a very tough act to follow
As far as what I use - Corel Aftershot Pro works really well, I find, with CCD cameras. For my K-S1 I have to use either Rawtherapee or PDCU5, as Corel doesn't even support the K-S1...
I created my own presets in Corel AP - basically stumbled upon something I liked and then created a couple small variations. The black and white one is the only one where, after having applied my preset, I used a film emulation plugin that it has for a Kodak black and white film (I think I used Tri-X developing for 12 minutes, which is why it added quite a bit of contrast).
Speaking of contrast, I take contrast away - learned that from you. I take away a lot of contrast, but that gets added back with the color curve that I apply. The color curve is basically 80% of it, and the rest is the lower contrast as I said, and dealing with any problems in the darker areas.
