Originally posted by Dartmoor Dave Also, has anyone managed to clean their K10D sensor successfully, and can you recommend a brand to use?
Dave - my own approach to cleaning any DSLR or mirrorless sensor (including my K10D-clone GX10)has been 100% successful, and it's difficult to cause any damage unless you're extremely careless:
1) Start off with the camera's own dust removal function, running it a couple of times in succession with the lens off and the camera pointing down
2) Next, use a bulb blower - again, if you can point the camera down while doing this, it's better
3) If spots remain, use the Pentax O-ICK1 gel-stick to lift off any debris, cleaning the gel on the sticky paper provided after each lift-off
4) Finally, if the above still hasn't got rid of everything, wet clean using good quality 17mm DSLR sensor swabs and Eclipse or other good quality, high purity cleaning fluid
5) In case the wet cleaning has left behind any fibres (it shouldn't, if good quality swabs were used), return to step 1
Try one step at a time, testing after each one. Don't skip any steps, and stop as soon as there are no more spots. With this approach, you minimise any risk of scratching the colour filter array on top of the sensor, which most frequently happens when debris is pulled across it with swabs or other tools. By using the gel-stick before any wet clean, you'll remove any nasties in advance.
I get my cleaning supplies from
Camera Cleaning & Protection Products | Camera Bags, Straps & Grips | Camera, Video & Phone Accessories | Just Ltd. Not the cheapest, but not badly priced either, and very good service.
Hope this helps.
