Originally posted by ChristianRock Paul has been inspiring me to get my manual tele zoom out again... so I grabbed my lovely SMC-A 70-210mm f4 and I'm posting pics from it all over the forum, so many keepers
I can't believe I haven't given this lens the proper attention it deserves...
Here showcasing colors from the K10D, of course... such a great combination of camera+lens...
Originally posted by wtlwdwgn K10D and A 35-105. Xpst.
Those A series lenses certainly do give popping colours with the K10D! I've found the same with my A 50/1.4 and 35-70/4...
---------- Post added 06-05-17 at 12:41 PM ----------
When I got my K10D a couple of months back I was keen to try my M42 lenses and K mounts. The M42s I'm used to using manually stopped down on Aperture Priority (Av) mode, as that's how I've used them with adapters previously with Pentax K film bodies, Contax film bodies and my Sony NEX and a100 digitals. The process is much the same with the K10D, and especially good with preset aperture lenses. I do have to tweak exposure a little and find mostly I'm compensating -0.5 to -1.5. In fact I've started to leave it on -0.5 as the default, then gone under a little more if I've got overexposed clipping (thanks to this thread learning about having the histogram on by default in playback review mode, and the "blinkies' on in the instant review mode). So it's very workable.
With SMC and M lenses (I have an SMC Pentax 55/1.8, SMC Pentax 135/3.5, M 50/1.7, M Macro 50/4, M Zoom 75-150/4 plus a Rikenon 50/2) I'm using Manual (M) mode and the green button. I set the lens to the required aperture, compose, focus, then press the green button to meter, then shoot. But it virtually always overexposes by 1-1.5 stops. So, I've adapted to the same process, but after pressing the green button, then turning the front wheel two clicks to increase the shutter speed by a stop, then shooting. I would like to just set the exposure compensation but being M Manual mode you can't do this, so
every time you take a shot you have to manually tweak the exposure.
I just find this whole process an bit fiddly and almost
too manual.
The M42 lenses with Av mode is near ideal for me. Especially now I have the magnified eyepiece and split prism focusing screen installed.
My questions to you experienced K10D users are -
1. Is M mode the only way to use SMC/K and M series lenses?
2. Do your K10Ds also almost never give the correct exposure with SMC/K and M lenses?
If there's no other approach than what I'm doing, I think I might sell up my SMC/K and M lenses. The only way I have really that isn't duplicated/equalled with a Takumar in M42 mount is the Macro 50/4, but there is an equivalent Takumar I would get to replace it, for about the same money, or even the Tak 100/4 Macro.
Then I'd just stick to M42 (mostly Taks, but a few FSU lenses too (Helios 44-2, Jupiter-37A, Jupiter-11) and a couple of Zeiss (Flektogon 35/2.4 and Sonnar 135/3.5) most of the time.
I prefer the more muted and realistic colours of the Taks to the SMC/K and M series somehow too. Then I'd use my two A series lenses (50/1.4 and 35-70/4) for when I do want more vivid popping colours. I don't have/want/need any AF lenses.
The A series incidentally are much the same in use to the M42 lenses, but with auto stop down of course. I also use them on Av mode and also usually need a bit of exposure tweaking, but again as with M42s I can take a couple of sample shots, set the exposure compensation as a starting point then tweak now and then as required where the lighting is more tricky. It's a relatively smooth process after that.
Thanks in advance, look forward to hearing your thoughts and experiences.
I did manage a couple of decent shots with the SMC 55/1.8 today, even if they were fiddly in getting there!
EDIT - By the way when you want to add a new reply with a new heading, why does it just then merge it with your previous reply instead and the separate heading disappears??
Reason: Confusion over title heading disappearing.
