Show Printable Version 12503 Likes Search this Thread
03-13-2020, 09:46 AM - 3 Likes   #5551
Dartmoor Dave's Avatar
QuoteOriginally posted by subsea Quote
So, you're telling us that you won't sacrifice for the sake of your art! Did I get that right?
I sacrifice for the sake of my art every full moon. Usually a live sheep or goat. I'm just not willing to get wet for my art.
03-13-2020, 11:53 AM - 3 Likes   #5552
paulh's Avatar
The "Cupcake House" in Coppell, TX. DA16-45 on K10D:
03-13-2020, 04:38 PM - 1 Like   #5553
paulh's Avatar
Rocks at Santa Paula Creek, Calif. DA18-135 on K10D:
03-14-2020, 09:07 AM - 1 Like   #5554
QuoteOriginally posted by Pan Kleks Quote
This is a serious question. Has anyone successfully used the K10D for action shots? I've been trying to get some photos of my 5 year old running around or swinging on a swing or tire swing and her face always comes out somewhat blurry. I have two K10D cameras and kit lens plus the 31 and 77 amigos and they all come out the same. Someone already mentioned using the back focus button and center square only and I've tried that as well.
* I would shoot in manual focus mode. I shoot mainly manual focus lenses on my K10D anyway, mostly shooting my small stable of AF lenses with my K-R.
* Then, I'd try to shoot only shutter speeds of 1/500th sec or faster, too freeze action -- unless I was panning the camera with the action, then maybe I'd go down to 1/125th.
* To be able to stop down a little, and get a little depth-of-field, I'd probably dial the ISO up to 400. I nearly always shoot my K10D at ISO at 100.
* Then I'd focus on an area where the action is either continually passing through or is likely to pass through, and snap away when it gets there.
All of my suggestions are conditional, because I hardly every shoot action shots. I'm a slow, pokey, methodical photographer. The breeze moving what I'm trying to shoot is the main action I contend with.
03-14-2020, 11:07 AM - 1 Like   #5555
cartesio's Avatar
03-14-2020, 05:22 PM - 1 Like   #5556
ChristianRock's Avatar
The DA Limiteds and tthe K10D seem like a match made in heaven ... I am now convinced that I will have the 70 and the 21 in addition to my 35mm f/2.8 Macro... I'm also c onvinced that the low prices of the SMC versions are here to stay - though in the case of the 21mm I think i'd rather have the HD, I think it's the one that has the most difference between the HD and SMC versions. Hopefully this year!
03-15-2020, 09:54 AM - 3 Likes   #5557
cartesio's Avatar
I like the 70 ltd a lot. I equally like the M 100 2.8. A step below the FA 35mm and FA 50mm.
03-15-2020, 10:31 AM - 7 Likes   #5558
Across the clapper bridge and over the leat. Or if you prefer it in non-Devonian English: Across the conveniently positioned big flat stone and over the man-made stream.
03-16-2020, 01:18 PM - 1 Like   #5559
cartesio's Avatar
03-16-2020, 05:00 PM - 7 Likes   #5560
Amigo 31.
PENTAX K10D  Photo
03-17-2020, 02:09 PM - 3 Likes   #5561
cartesio's Avatar
03-18-2020, 01:23 AM - 7 Likes   #5562
A couple of real posers in the fog.
Last edited by Dartmoor Dave; 03-18-2020 at 02:13 AM. Reason: Changed to B&W version
03-18-2020, 07:56 AM   #5563
tonyzoc's Avatar
I have a question about using the battery grip. Under the Menu/Settings/Battery settings it always shows the 2nd battery as crossed out. I read through the PDF manual and I'm not understanding how those icons work. When does the lower battery light up green like the top one?
03-18-2020, 11:39 AM   #5564
tonyzoc's Avatar
QuoteOriginally posted by tonyzoc Quote
I'm thinking either the battery contacts have a problem...although release works fine...or the body requires a battery, dead or not, for the grip battery to work (?).
03-18-2020, 12:24 PM   #5565
I have to ask the really obvious things first, so please understand that these questions are NOT intended to insult your intelligence:
Is there actually a battery installed in the grip? (The grip hasn't got a built-in battery, it needs a D-Li150.)
Have you swapped the batteries between the body and the grip to see if you get the same result?
Have you tried it with no battery in the body, but a battery in the grip only?
Again, sorry if these seem like insultingly obvious questions. I just want to make sure you've tried those steps.
allen, bird, camera, cameras, clicks, comparison, da, dslr, ff, flickr, images, k10d, k5, k5iis, leica, lens, nikon, pentax, photography, pictures, post, price, prix, ray, skin tones, time, version
I started a K-5 Praise thread, now the Complaint thread imtheguy Pentax K-5 & K-5 II 46 11-01-2010 09:20 AM
Suggestion Add Previous/Next Thread links at the top of each thread indytax Site Suggestions and Help 3 03-17-2009 05:40 PM
Iceemn360's K10d Photo Thread Timtast1c Post Your Photos! 50 01-10-2009 02:43 PM
Mandatory thread from new K10D owner :) Edvinas Pentax DSLR Discussion 9 12-08-2006 07:34 PM
All times are GMT -7. The time now is 06:10 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
