Originally posted by rodcy
The only answer to narrow dof with macro or still life is focus stacking!. I use software called Franzis Projects. It's easy to use and not too expensive.I think Affinity Photo does it too. Of course a shorter lens might help but then you're right on top of the subject and that can cause shadow. Have a look anyway.
This isn't something that I have considered before. I have to admit I tend to treat digital photography a bit like film, so try to get what I want in the camera, and use post processing to do a bit of cropping and fiddle with the colours. I am getting more into post processing now and use GIMP as its free and a pretty good alternative to Photoshop.
I have just had a very quick go to check this out and it seems very simple to do. The attached compilation show 3 taken images and the final stacked image bottom right. Ok I need to be a bit more careful about the setup but I think I will be doing a lot more of this going forward.
