11-17-2013, 07:23 AM   #1
Transferring images up to Android devices
Hi folks, I have a K5 and usually transfer my images straight to my laptop. Recently I bought an Android tablet and it only has a micro USB connection. Does anyone know if I can simply use a USB to micro USB converter then plug my K5 straight into my tablet?
Any help appreciated.
Thanks
11-17-2013, 07:43 AM   #2
It depends on the tablet, some support USB host mode, many don't. If yours does support it, you can use a simple cable like this one:
Amazon.com: eForCity Micro USB OTG to USB 2.0 Adapter compatible with Samsung
The camera will need to be set to MSC mode so it shows up like a thumbdrive.
11-17-2013, 07:53 AM   #3
bwDraco's Avatar
It depends on whether the device supports USB On-The-Go (OTG). If so, then you can use a third-party app to transfer files over USB using an appropriate cable.
I personally use a Kingston MobileLite Wireless (model MLW221) for wireless transfer of files from my camera to my Nexus 7. The device runs for about five hours on a charge, and is used with an app to transfer files from and to flash drives and SD cards. You can also read data from the MLW through a web browser if you know the IP address of the device, and it can also act as an SD card reader for PCs. It's not the fastest device, being limited to Wi-Fi speeds, and it will take a while to transfer large amounts of data, but it gets the job done.
(Of note is a bug in older firmware versions that causes transfers of large files (>32 MB) to an attached USB flash drive or SD card to fail, requiring the MLW to be reset. Transfers from a flash drive or SD card are unaffected. I've been in touch with Kingston technical support with this issue, and the bug seems to be fixed with the latest firmware.)
--DragonLord
11-17-2013, 08:09 AM   #4
If it is of any interest I've just checked my K-3 and the USB connection works perfectly with my Samsung Galaxy Note.
My K-r also works well whereas the K-30 does work but very slowly. However the K-30 is just as slow even with a PC.
11-17-2013, 10:05 AM   #5
I don't own an OTG enabled device, so I use a microSD to SD adapter.
11-17-2013, 11:04 AM   #6
Louicio's Avatar
You could also use an Eye-fi card, they can be programmed to upload JPEG and Raw (if you get certain models) automatically.
11-17-2013, 11:08 AM   #7
With the "USB connection kit plus" for a galaxy tab 2, when the camera is plugged in it comes up with Camera Importer and all works fine. I never thought of trying this until you mentioned it today. - Thanks for asking.
11-17-2013, 12:32 PM   #8
QuoteOriginally posted by DragonLord Quote
--DragonLord
Thanks folks.
android, camera, dslr, images, k5, photography, tablet, usb
Problem transferring photos K30 to Macbook changemaven Troubleshooting and Beginner Help 6 11-02-2013 06:11 PM
Back up sd card pictures to Android phone on the field? lightbulb Troubleshooting and Beginner Help 9 06-24-2013 12:22 AM
Transferring images - card reader or camera cable? ChooseAName Pentax DSLR Discussion 26 06-19-2013 01:19 PM
Transferring pictures to Picasa Masaryk Pentax K-r 2 10-14-2012 10:27 AM
Photoshop for android, how to import images from usb storage (camera sd)? fikkser Digital Processing, Software, and Printing 2 04-25-2012 12:39 AM
All times are GMT -7. The time now is 04:22 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
