04-02-2008, 06:20 PM   #1
ME Super lenses with a digital body? - Is it possible?
Hello all..... I'm a newbie just joined today and I have a question. I have 2 Pentax ME Super bodies with a selection of Pentax, Tamron and Vivitar lenses. I am looking to buy my first Digital SLR and wonder if there is a Pentax (or other DS) that I can still use these lenses with? If the answer is yes, then are there any other technical things I need to know, EG: any limitaions or such like using old manual lenses with a Digital cameras? I am looking to spend £500 or preferably less on decent camera over 8 mpx. Im an ex pro and I mostly do people and landscapes and lots of experimental stuff, some of which I will post here when time is right. Thank you for reading this and thank you in advance for any (and all) advice that you may have for me. Have a happy day.....Max
04-02-2008, 07:20 PM   #2
Hey,
The main reason I switched to Pentax is that almost all pentax lenses ever made are compatible with their DSLR's. Even screw mount lenses can work with a 30-40 dollar adapter.
All of your lenses should work with a K-series DSLR, but for the M lenses it will only meter for wide open, also no AF for these. For A lenses pretty much everything but autofocus will work.
Have fun,
ranamar
-On my k10d, I use a SMC M-1:2 50mm, I think the same lens supplied with the Me Super, and besides the mentioned metering issues, it works great.
I may even be wrong about the metering, but this is what I was told.
04-02-2008, 07:41 PM   #3
Canada_Rockies's Avatar
QuoteOriginally posted by Max Quote
I use 30 year old M series lenses on my K10D. Every Pentax dSLR can handle them. They will not expose in automatic exposure (and obviously, are manual focus as well), but will expose just fine in manual mode (M on the mode dial). Check out the threads on this forum after you get your dSLR to check out the procedure with your particular camera.
04-02-2008, 10:12 PM   #4
ryan s's Avatar
I have one AF lens...check my sig for the rest of the...uhh...family
04-03-2008, 03:32 AM   #5
Mike Cash's Avatar
QuoteOriginally posted by ranamar Quote
Hey,
Have fun,
ranamar
You are semi-wrong about the metering. Metering with M lenses on DSLRs can be done....just not automatically. You gotta go mashy-mashy on a button.
04-03-2008, 05:18 AM   #6
Ivan Glisin's Avatar
Only partially correct and applies to Av mode only. In M mode though there are other options: (a) DOF stops down the lens and activates continuous metering so that you can adjust both shutter speed (using camera dial) or aperture (using lens aperture ring) for desired exposure; or (b) by pressing AE-L (is it the Green Button on K10/20?) camera automatically stops down the lens and sets shutter speed based on manually set aperture. In both cases camera actually meters the real light passing through stopped down lens, while with A and newer lenses camera recalculates Tv without stopping down based on Av setting and lens aperture range information -- that's what most of those contacts are for).
Note: This assumes that camera is set to Shift Tv on AE-L (Green) which I use. I think this setting is in the custom menu.
04-03-2008, 06:04 AM   #7
Banned
like Ivan and Mike said you can properly meter with a M lens just fine, it just wont do it for you is all.
camera, dslr, lenses, pentax, photography
Using an M-lens (135mm 3.5) on Digital Body jope88 Pentax DSLR Discussion 3 08-09-2009 04:37 PM
switching to a 6X7 digital body isabel Pentax Medium Format 16 07-21-2009 08:58 PM
Digital Lens (16-45 DA) on MZ-5n body litbos Pentax Film SLR Discussion 3 07-09-2009 12:46 PM
For Sale - Sold: Pentax 100 Super Body + Lenses + Bag! Kaelyn84 Sold Items 17 06-02-2008 06:12 PM
All times are GMT -7. The time now is 04:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
