11-25-2013, 08:00 AM   #1
adwb's Avatar
raw on your lcd
There once was a thread here that contained info to get the camera to display a histogram on the rear lcd that actually matched the raw image rather than the jpeg the camera displays.
This resulted in a awful image to view but you knew you were safe with the histogram for your raw.
there was a fancy name for this technique but I cant remember what is was called or how you did it.
I tried it and it worked but I cant find any info doing a forum or Google search, I guess i'm using the wrong search terms.
any help here any one????
11-25-2013, 09:42 AM   #2
Canada_Rockies's Avatar
My histograms are close (K10d). I put all the in camera jpeg settings to neutral. No saturation up, no contrast no nothing. Just plain 0 on all the sliders.
11-25-2013, 10:37 AM   #3
QuoteOriginally posted by Canada_Rockies Quote
Same here. In fact, it never occurred to me that they represented anything other than the value distribution from the RAW capture.
11-25-2013, 10:48 AM   #4
Na Horuk's Avatar
Yeah, the histogram is of the jpeg preview. The problem is that it is based on a photo which has already been developed.
The jpeg has: a) less data b) it changes WB c) it affects tones and contrasts d) other options can also have effects if you have them enabled, like shadow and highlight correction, distortion correction, etc.
I think I remember reading a similar tutorial as to what you are asking, OP, but I do not know the details. I am also very interested in this. I think the person did something to make the "custom WB" reflect actual default sensor WB (so the camera didn't fiddle and move the blue/yellow around) and set the sliders at closest to actual 0 changes (the problem is that with some cameras, the 0 value still does something). After that he shot raw and exposed to the right as much as he could. In post, he would bring down the brightness and fix white balance. Only downside to this that I see is that a) it is hard to get the white balance right in post and b) it takes much more time to process these photos
The upside is that you get maximum sensor performance and less noise. Since you are esentially overexposing, this also means you probably get a faster shutter speed and thus sharper photos.
11-26-2013, 01:25 AM   #5
adwb's Avatar
Na Horuk, I'm glad I'm not thte only one to remember this , and yes it was some odd white balance shift that was involved.
I get realy frustrated when I can't find things later.
11-26-2013, 01:26 AM   #6
adwb's Avatar
Na Horuk, I'm glad I'm not the only one to remember this , and yes it was some odd white balance shift that was involved.
11-26-2013, 05:09 AM   #7
I think that this thread will help: https://www.pentaxforums.com/forums/6-pentax-dslr-discussion/68043-finally-ca...histogram.html
Then search "uniWB"
Here's a start: http://www.guillermoluijk.com/tutorial/uniwb/index_en.htm
11-27-2013, 12:54 AM   #8
adwb's Avatar
Paul thank you it is uiWB I re found it last night there's loads on it I used the white light method last time I tried it that worked well.
camera, cant, dslr, histogram, image, info, lcd, photography, search
Reviewing shots made in RAW on LCD in B&W / K-X. Ascendant Imaging Troubleshooting and Beginner Help 9 01-27-2012 09:50 AM
On-camera LCD vs Computer LCD Andi Lo Pentax DSLR Discussion 6 02-07-2009 01:59 AM
To fix hot/dead pixels on your LCD monitor try this... Arpe General Talk 4 09-24-2008 12:25 PM
Save your LCD ebarbaric Photographic Technique 15 01-03-2008 08:10 AM
your current take on CRT vs LCD button Digital Processing, Software, and Printing 11 09-13-2007 07:22 AM
All times are GMT -7. The time now is 05:16 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
