Originally posted by Kozlok Don't forget you need a WR or * lens before taking it out in the rain...I don't see one in your signature block. I put my 18-135 on my k-30 and ran it under the sink (at very low pressure) to check while still in my 30 day return window. Took it out in a tropical storm later that summer. 20 inches of rain later, not a single hiccup.
Thanks. I do have the 18-135WR (I think that is the range.) At some point Pentax will build me a WR FA31 and I will become a very happy camper.
Of course I am also looking very closely at the new 20-40 Limited and may end up moving that way in early 2014.
As for my sig, I have so many cameras and lenses there is no possible way to fit them all in there. The ones that I have listed are the ones I seem to use more than any of the others.
I suppose I should figure out how to add in the 18-135 since it will be the primary walk around.
Interestingly, my LX is very reliable in the rain and I still do use it as well. The lenses aren't WR but I set my reliable old M50/2 at f8 or f5.6, wrap a tight rubber band around the base of the lens where it meets the camera, put a UVa filter on the front with a hood and just go do my thing. The camera holds up just fine and has never had any trouble. The lens does end up getting pretty damp sometimes but it dries out inside pretty quickly when I get back to the house. Eventually I imagine it will begin to fall apart, but if it does I'll buy another for $25 and move on. Of course changing film is where things can get dicey. If I can't dry the back of the camera off and get under shelter, I don't open the back. This is really where the K5iis overtakes the LX in my opinion, and was the entire reason I bought it.
