11-30-2013, 03:06 PM   #1
sterretje's Avatar
K5 memory cards
When I bought the K5, I added two SanDisk Extreme III 8GB cards (30MB/s, class 6) and I'm happy with them. It's time to add a few more but those no longer exist.
These seem to be the closest I can find: Ultra SDHC and SDXC Memory Card by SanDisk only difference seems the (irrelevant for me) class rating and I'm planning to buy two 16GBs (8GB is a bit tight at occasion).
I will stick with SanDisk (they have never failed me).
1)
Are those the right models?
2)
Options for use in the K10D and K100D (assume up-to-date firmware).
2a)
K100D manual mentions SD cards (not SDHC). Will they work? Up to which capacity?
2b)
K10D manual mentions SD cards and SDHC. Up to which capacity?
Thanks in advance for advise.
11-30-2013, 04:17 PM   #2
The k10d will take sdhc cards up to 32 gb. I believe that the k100d will too, after a firmware update.
Standard SD cards are up to 4 gigabytes though most are only two gb or smaller.
11-30-2013, 05:56 PM   #3
kkoether's Avatar
They are just called SanDisk Extreme now. They are still available here in the USA. Not sure about South Africa though.
SD Cards for DSLRs and Other Digital Cameras from SanDisk
12-01-2013, 03:40 AM   #4
The Ultra class cards you link may be considerably slower to write than the ones you've been using.
Using a K10D and later K5, I went from 4GB Extreme III class 6 cards (purchased late 2008) to a 16GB card that looks similar to the ones you link. Mine is labeled class 6, not class 10, but the label otherwise looks identical -- Ultra, SDHC I, and definitely the same 30MB/s rating printed on it. I bought it maybe early 2012.
I was surprised how much more waiting I had to do for the newer card. I'm not much of a high-speed shooter -- very rarely use continuous shutter, never fill the buffer -- but I'll often take several single shots in sequence, usually to bracket focus. There's noticeably more of a delay with the newer card between taking a few shots and being able to e.g. enter playback. A quick test on my K5: 3 RAW+jpeg shots in continuous (Hi) with the lens cap on, shutter press to playback on (i.e. including shooting time) takes about 4 seconds with the old card and 7 with the new. Subjectively, it adds up to a fair amount of waiting on the card when I least want to, enough that I've since decided it's worth paying something of a premium for faster cards.
FWIW B&H lists read and write ratings for their various SanDisk cards. For the class 10 Ultras you link they report _MIN_ write speed of 10MB/s. For the Extreme cards kkoether mentions, it's _MAX_ 45MB/s and up.
Anybody know of anything more comprehensive, or more directly comparable?
Meanwhile, I can confirm that my 16GB SDHC card works fine in my K10D aside from the subjective speed issue, and that a 64 GB Sony class 10 SDXC (slower again than either of the above in the K5, by the way) isn't recognized at all.
12-01-2013, 09:34 AM   #5
sterretje's Avatar
Everybody thanks for their replies.
QuoteOriginally posted by kkoether Quote
They should be; I'm aware that there are still 'extreme' cards; they however come at a premium; extreme pro is over 3x the price of the Ultra I linked to but I will see if I can find the normal 'extreme'.
QuoteOriginally posted by josh h Quote
Thanks for that. There should not be a difference. 30MB/s specifies the maximum throughput. The class rating gives the minimum sustainable throughput and is only relevant for video. Source: Difference between Speed Class, UHS Speed Class, and Speed Ratings (performance) for SD/SDHC/SDXC cards. The K5 can't make use of the 45MB/s as far as I know and hence the looking for 30MB/s class 10 cards.
I seem to remember that when the K5 came out, there were some discussions around SDXC.
PS Found the SanDisk Extreme 16GB 45MB/s SDHC Card (at a 50% premium)
12-02-2013, 04:49 PM   #6
QuoteOriginally posted by sterretje Quote
Interesting, thanks. Good luck with the new cards.
camera, capacity, cards, class, dslr, k100d, k10d, k5, memory, memory cards, photography, sandisk, sd, sdhc
memory cards judys Troubleshooting and Beginner Help 6 09-18-2013 04:31 PM
SD memory cards... alamo5000 Troubleshooting and Beginner Help 10 06-13-2012 05:57 PM
XQD memory cards jpzk Pentax Camera and Field Accessories 2 04-27-2012 01:26 PM
dane memory cards fewing1 Troubleshooting and Beginner Help 4 03-01-2012 07:16 PM
Case for Memory Cards Belcik Pentax Camera and Field Accessories 5 02-23-2012 10:32 AM
All times are GMT -7. The time now is 10:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
