12-07-2013, 02:14 PM   #1
Pictures come out dark
So I went to a football match with a used ist DL2 i just bought just to test it. I can't seem to find the problem why photos are so dark. And the other thing is I can't access the menu just, gallery, delete button and fn button..
Probably something wrong with the button, is this an easy cheap fix?
Thank You
12-07-2013, 03:14 PM   #2
Can you post some samples with EXIF intact? I took the ist D out and the pics seemed to come out darker than the ones from a more modern camera, but they should still be properly-exposed & recoverable in post if needed.
12-07-2013, 04:23 PM   #3
I attached the photos. I would try fixing the problem, but I can't access the menu
12-07-2013, 06:14 PM   #4
What lens were you using? The aperture and focal length are blank, indicating an M series manual lens. If this is the case then the Av exposure mode you used is not going to work properly.
12-07-2013, 06:33 PM   #5
It's a really crappy lens, I just bought it for some tests for just 10 pounds. COSINON Z 80-200mm f4.5 Pentax K fit
So this might be the problem? Also I can't access the menu, button won't work, is this an easy fix?
12-07-2013, 06:48 PM   #6
You're going to need to use M mode with that lens and use the AE-L button for stop down metering.
As for the menu button problem, I don't know, if it is just the button it could be fixed. You can find the service manual here, the password for the PDFs is in the txt file. The full disassembly guide is in the one for the *istDL.
http://www.pentax-hack.info/firmware/k10_gx10/older_sm.zip
12-08-2013, 05:45 AM   #7
Ok thank you! One more thing, my firmware is old. but i can only find the update for the ist DL not ist DL2, will it work for me too?
12-09-2013, 09:48 PM   #8
ScooterMaxi Jim's Avatar
QuoteOriginally posted by Andreas9 Quote
No, I wouldn't try that. This is the correct page for the most-current DL2 firmware:
Software Downloads : Support & Service | RICOH IMAGING
button, camera, dark, dslr, photography
new lens = dark pictures bunkachunk Pentax DSLR Discussion 5 09-05-2013 10:53 AM
Pictures stuck inside and won't come out ...lol lor bell Troubleshooting and Beginner Help 2 10-30-2012 05:24 PM
Pentax *ist DL - pictures come out black? jamart27 Troubleshooting and Beginner Help 12 01-07-2012 01:02 PM
Why all my pictures come out grainy? Secret Elkina Troubleshooting and Beginner Help 23 02-03-2011 05:17 AM
wanting to come back from The Dark Side, help me out here. 123K10D Pentax DSLR Discussion 13 01-15-2009 05:59 PM
All times are GMT -7. The time now is 02:11 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
