04-06-2008, 09:39 AM   #1
Cleaning k100d.....can't get the hair off :(
Hey all, I've been spending some time today cleaning my camera and lenses because they were a bit dirty. After cleaning the camera, I look through the viewfinder and notice a hair that I just can't get off!!!!!!! It doesn't seem to be on the mirror and I've cleaned the viewfinder part inside the camera. It seems like it's on the inside of the viewfinder now and I have no idea how it got there. Of coarse I'm looking through the viewfinder with no lens.
This mysterious piece of hair wasn't there before i cleaned the camera.....go figure huh.
Bummer....thanks
04-06-2008, 10:36 AM   #2
Mike Cash's Avatar
It sounds like the hair is on top of the focus screen (the "viewfinder part inside the camera"). You can open the little trap door the focus screen is mounted on for cleaning, but since the focus screen is very easy to damage I would recommend just getting used to the hair. After a while you won't even notice it. At the very least read up carefully on how to access the area and what precautions to take to avoid damaging the screen.
Also, it may not be a hair. What looks like a hair is usually a very fine fiber. Hair looks more like a rope inside the viewfinder (thick, since everything gets a little magnified). Also, be aware that opening it up to clean one thing almost invariably results in the introduction of some other unwanted dust/fiber somewhere.
04-06-2008, 03:26 PM   #3
This problem has been addressed before in the Forums. A search led to this helpful PDF of instructions from the nice folks at KatzEye: http://www.katzeyeoptics.com/files/PENTAX.PDF
Should help you remove your focus screen for cleaning and safe replacement. I followed it a month or so ago when a big dust particle showed up on my K10D's focus screen. Pay attention to the orientation of the tab on the focus screen before you remove it, and replace it in the same orientation, and you'll do fine, I'm sure!
04-06-2008, 09:10 PM   #4
Canada_Rockies's Avatar
QuoteOriginally posted by christinelandon Quote
And don't forget to put the spacer in the right position!
camera, dslr, hair, photography, viewfinder
Cleaning the Sensor on K100D modeltweaker Pentax DSLR Discussion 11 04-23-2010 11:35 AM
Eclipse standard or E2 cleaning fluid for k100D and k20D? raider Pentax Camera and Field Accessories 1 12-24-2008 03:47 PM
Automatic Sensor Cleaning in k100d Super and k10d superfuzzy Pentax DSLR Discussion 3 11-19-2007 04:18 PM
K100D Sensor Cleaning Jimsi777 Photographic Technique 2 11-16-2007 01:19 PM
Weird Sound of K100D (K10D 2?) in B/Sensor Cleaning Mode RiceHigh Pentax DSLR Discussion 13 01-05-2007 07:01 AM
All times are GMT -7. The time now is 02:04 PM. | See also: NikonForums.com, part of our network of photo forums!
